06-19-2018, 10:52 AM | #1 |
Rep 453
Need to replace brembo BBK rotors
So my front and back on my Dinan/brembo bbk have warped and I need to replace my rotors.
Size on front is 380x34mm and rear is 380x28mm. I've been reading it's possible to run the stoptech rotors, will it work for this setup? What pads would I have to go with? Does anyone know the best spot to get brembo rotors/pads for the best price currently? Any advice would be greatly appreciated. |
06-19-2018, 02:11 PM | #3 | |
Stop the hate, get a V8
3853
Rep 8,625
I'd give Dave Zeckhausen of Zeckhausen Racing (www.zeckhausen.com) a call to see what he knows about rotor backward-compatibility. He stocks those parts too. I agree with the above that it's unlikely you warped the rotors. Try to re-bed the brakes.
Past: 2011.5 M3 sedan ZCP |
06-19-2018, 02:12 PM | #4 | ||
Rep 453
06-19-2018, 02:16 PM | #5 | |
3853
Rep 8,625
He is a busy guy so you may need to leave a voicemail. If it's not urgent, just email him.
06-19-2018, 02:19 PM | #6 |
Rep 453
You can see it in the pic. Right around the hat. Tire also has a bubble waiting to receive to rotors to put my new tires on
06-19-2018, 02:24 PM | #7 |
3853
Rep 8,625
I can't see anything, the photo is too small. You're saying the warping is so bad that you can see it? If so, that's crazy, and I'd want to find out why it happened.
06-20-2018, 01:50 PM | #9 |
Rep 453
Thanks for referring Zach. Very insightful and helped out. Unfortunately he only stocks stoptech
06-20-2018, 01:51 PM | #10 |
Rep 267
Due to the carbon content of most rotor iron, the rotor will crack before it warps enough to see when tucked behind a wheel. You *might* be able to see an extremely warped rotor if you took the wheel off and inspected it closely, but even then it'd be tough. Rotor warp-age is a matter of a few hundredths of an inch (~0.025" would be pretty extreme run-out), and even then it is rarely caused by overheating, especially on 2-piece rotors. Excessive run-out is typically a manufacturing issue. I would suggest having the run-out and thickness checked before investing in new rotors. As others have said, you may just have pad deposits.
06-20-2018, 02:19 PM | #11 | |
3853
Rep 8,625
Did you get the run-out measured? If so, what was it? Have you spoken to Brembo about it?
06-22-2018, 09:58 AM | #12 | |
Rep 453
06-22-2018, 07:35 PM | #14 |
Rep 6,285
warping is where the rotor runs out of section (this can be checked with say a dial indicator by removing the wheel and placing it on the rotor) and is not necessarly be seen in a pic, only when the rotor is spinning
I think you're referring to the lip around the rotor hat? What this is, is the section of the rotor that isnt wept by the brake pad, so the rotor remains the same section as a new rotor. Get a shop to check rotor thickness with a set of micrometers but yours look fine to me TBH |
06-22-2018, 08:56 PM | #15 |
Rep 5,858
Agree with the above post. Your pad radial depth is less than your rotor ring radial depth which results in a small area of the rotor ring not being used.
06-22-2018, 08:57 PM | #16 |
just another M3
514
Rep 1,152
Sadly nothing seems wrong with rotor but the fact they are near due for replacement. Two piece rotor hardy wrap. I cooked mine to 1600 degree F at track no wrapping. But should replace since it's due
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
06-22-2018, 10:40 PM | #18 | |
Rep 3,140
Drives: 2014 M5 6MT
Pad deposits can get so bad, that they can easily measure in the 0.002"- 0.009" range and easily make a brake vibration pretty severe. The largest runout I've measured to date was 0.014", at which the customer opted to replace the rotors with a Stop Tech BBK.
2014 M5 6MT
06-22-2018, 10:42 PM | #19 | |
Rep 3,140
Drives: 2014 M5 6MT
If you're hell bent on replacing the rotor rings, contact dinan directly. they sell the replacement rings.
2014 M5 6MT
06-23-2018, 06:47 PM | #21 | ||
Rep 453
06-23-2018, 11:14 PM | #22 |
Rep 3,140
Drives: 2014 M5 6MT
Cool bro. Good luck finding them outside of the manufacturer, or dinan, and they would have to order them from brembo for you. I asked.
2014 M5 6MT
