02-09-2020, 10:16 PM | #1 |
Rep 163
rear end link bottm bolt
Hey guys,
I'm a bit of a dilemma as I'm trying to install rear end links. There is not enough space for the bottom bolt to come out since it hits the axle hub (see pic). So I ended up cutting the bolt using a dremel. I've searched and found out that shaving off about 4-5 threads on the new bolt will help clear between the axle hub and spindle but I prefer not to go that route. So I was wonder if by unscrewing the axle nut and the arms, would I be able to pivot the spindle to create more space? The spindle is whats really in the way at this point and about an inch of clearance to get the new bolt through.
02-10-2020, 02:04 PM | #2 |
Rep 1,055
I went with a shorter, 10.8 grade bolt (oem was 8.8) to install a hotchkiss swaybar with upgraded links. I used threadlocker and have had no issues. Sharing my experience in case you'd like to consider an easier solution.
I didnt think about pulling the spindle off. From what I've read, its a pia, not sure if this is because most of the diys I've read are about replacing bearings. Last edited by M43S7RO; 02-10-2020 at 03:05 PM.. |
02-10-2020, 02:34 PM | #3 | |
Rep 933
Drives: E90 M3
I had the same clearance issue with the trailing arm bolt and grinded down a side of the washer to get it out. New bolt came with a free spinning washer so getting it back on was not a problem. In your case a shorter bolt wouldn't hurt as long as it's relatively the same hardness. |
02-11-2020, 05:32 AM | #4 |
///M
160
Rep 190
Can someone chime in who's replaced the long OEM bolt with a new shorter bolt, and the specifications/dimensions for the new shorter bolt they used? Where did you buy it?
Thanks |
02-13-2022, 05:20 PM | #7 |
Rep 40
OEM is M8 x 45 mm.. not sure what the thread pitch is though.. the diagram on realoem.com - https://www.realoem.com/bmw/enUS/sho...diagId=33_1411 - shows the spec of the bolt and part number as well.
I bought several 8.8 grade bolts to try out - M8 x 40 mm, M8 x 35 mm, M8 by 30 mm.. not sure the much shorter ones will be long enough but hopefully, the M8 by 40 mm works fine Last edited by e9x_m3; 02-14-2022 at 11:04 AM.. |
