01-15-2020, 08:43 PM | #1 |
Rep 933
Drives: E90 M3
It's everyone's favorite - what's that noise?
A little background: - Started noticing it yesterday. - It sounds like it's coming from inside the trunk/chassis - Happens only at 25mph and lower on bumpy roads, don't notice it at cruising speeds. - Typical "clunk" noise, not metallic or "clangy" at all - No modifications, all parts are OEM. Things I've done: - Checked out the suspension today and everything was tight with no broken bolts/bushings that I could see. - Emptied trunk and cabin - checked for anything loose or broken that would make a noise - Did the shock test a couple times in the rear with the car on the ground and nothing of note happened. - Also, I checked the suspension with ramps, so the suspension was loaded. The only thing I found that concerned me was the passenger rear half shaft's lateral play between the hub and diff felt like it was sticking a little before it would move side to side. The other side flows freely, however that was replaced about 10k mile ago. So it might be an age thing. My $.02 is I'm leaning towards suspension/chassis because I figure if it was something loose/broken in there it would probably be more sporadic and happen at all speeds. Anyways, here it is and thanks if you've stuck with me and made it to this point! |
01-16-2020, 06:41 AM | #3 |
Rep 933
Drives: E90 M3
02-06-2020, 08:44 AM | #5 |
Rep 933
Drives: E90 M3
Too many miles. Found the problem.
02-13-2020, 08:43 PM | #6 |
Astronaut
514
Rep 732
02-17-2020, 05:03 PM | #7 | |
Rep 933
Drives: E90 M3
If it's making the same noise then it could very well be the top hat bushings. I did replace all the connecting links prior to the shocks/struts as well, those make a similar sound too. Hope it helps! |
02-18-2020, 04:16 PM | #8 | |
Astronaut
514
Rep 732
Jacked the car up, tightened up the pillow ball bolts at the bottom of my struts, and tightened down the top hats. Car was smooth and quiet this morning on my commute to work! |
