08-14-2018, 11:33 AM | #1 |
Pwrdbym
60
Rep 343
headlight question
i have a 2010 e92 m3. I had to get a new rightside headlight due to a fender bender. The adaptive light is not centered in the ring see pics. also since the headlight was replaced both inner lights do not light up when i turn the steering wheel. can anyone tell me what the issue is.
08-14-2018, 12:13 PM | #2 |
Rep 2,907
Drives: 2011 E93 M3
The Adaptive servo linkage (ball joint) inside the headlight is either popped loose, broken or skipped threads. It will need to be opened up and fixed. Hopefully it's not broken, BMW doesn't sell all of the internal parts separately.
BOOF-M34451.50 |
08-15-2018, 03:52 PM | #4 |
Pwrdbym
60
Rep 343
Thanks but the headlight is brand new so I can return it.
08-16-2018, 06:15 PM | #5 |
Rep 1,326
The projector can be adjusted horizontally via the outer adjustment knob (can't be seen from engine bay unfortunately).
Do you have your headlight switch set to auto?
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
08-17-2018, 07:06 AM | #7 |
Pwrdbym
60
Rep 343
08-18-2018, 05:29 AM | #8 |
Pwrdbym
60
Rep 343
08-18-2018, 11:55 AM | #9 |
Rep 2,907
Drives: 2011 E93 M3
The knob adjusts the projector internally but it doesn’t have a significant range of travel. If you’re going to try to return it you better get on it before it’s no longer new or they blame you for breaking it.
09-28-2023, 07:40 PM | #12 |
Rep 146
