10-27-2013, 09:23 AM | #1 |
Rep 92
Switching trunk lids for downforce on the track/DD car?
Does anyone have a second trunk lid with aero for track use? I was going to try to get an e46 M for a dedicated track car but it's just not in the cards right now. I am going to do some work on my e92 over the winter to make it more track friendly and I intend on doing a few time trials next season.
I am thinking about the following combo: http://store.bimmerworld.com/bimmerw...wing-p906.aspx http://www.bimmian.com/OEM-&-CSL-Sty...r-E93-3-Series (OEM version) Does anyone here swap trunk lids for the track? How much of an effect did the aero have on your lap times? How difficult is it to swap? Do you have to reinforce the lid down to the frame for it to be effective? I have to lift going into the penultimate turn onto the straight at NJMP Thunderbolt (my closest track) and anything with downforce grabs a few seconds on me by the end of the straight. I think DF would alleviate that. Any feedback appreciated. Thanks |
10-27-2013, 09:54 AM | #2 |
11818
Rep 23,187
unless you have already extracted every last tenth of a second in other ways dont think aero is necessary. get the most out of your suspension, brakes, alignment, and weight loss program first. at least thats my feeling.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
10-27-2013, 12:37 PM | #3 |
Rep 1,718
user: 4sevens.com has two trunks for street and track on his e90 m3
10-27-2013, 03:16 PM | #4 |
Havin' a blast!
125
Rep 4,847
I know a handful here in SoCal who runs aero, and I don't think they swap the trunk before & after each track days. Too much work/trouble.
As for time, for the same car & same driver, I think aero is good for 2~3 second faster lap times. As for reinforcement, I think the mounts that are positioned closed to the middle require reinforcement due to the trunk lid flexing, which is why you see majority of the mounts positioned at the outer edges of the trunk lid. Anyhow, if you go w/ a wing, don't forget to consider a (deep) splitter at the front and may be even supplement that with canards. With wing only, you run at extreme speeds, the rear wing presses down but there's nothing at the front pressing down, so the car lifts at the front...
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
10-27-2013, 06:34 PM | #6 | |
Rep 658
10-27-2013, 06:52 PM | #7 | |
Rep 954
I'd imagine you are leaving time elsewhere on the track. What are you lap times? To me, aero is the last step. |
10-27-2013, 07:19 PM | #8 | |
Havin' a blast!
125
Rep 4,847
What's your opinion on wing mounts being outside versus closer to the center?
10-27-2013, 07:27 PM | #9 |
Rep 8,077
Drives: 11 E90 M3 Individual
What a massive PIA switching trunk lids. Brakes, camber, harnesses, checking out the car...oh...I have to switch trunk lids. Unless you're paying someone to do all of this work I wouldn't bother.
How much of a difference will it make? Don't know.
2018 F30 320iX Melbourne Red
10-27-2013, 10:44 PM | #10 | |
Rep 7,298
10-28-2013, 09:35 AM | #11 |
Rep 1,711
Swap trunk lid for the track? I just installed CSL style trunk lid on my m3 and let me tell you that it is a PITA. Not that difficult but it takes a lot of time. Looks much better than stock and it will stay that way.
Selling my stock trunk lid now. |
10-29-2013, 02:01 AM | #12 |
Rep 898
Question for you....how much benefit would I get for my car (997.2 GT3) if I put on a bigger Porsche Motorsport cup car wing ($8k cost)? I was thinking maybe the 997.2 GT3RS wing and decklid because it's more streetable but the cost is beyond high ($12k-$14k for wing, end plates, decklid, and intake).
10-29-2013, 10:01 AM | #13 | ||
Rep 658
You don't NEED a front splitter in order to have a wing. Even with just a wing, the car will be quicker around a track than no wing. You can adjust the wing for the correct balance, or change other aspects of the setup to balance it out. If you do have a splitter, then you can afford to add even more rear downforce. In general, pretty much every car will require a lot more rear downforce relative to front. I think there's more strength for a stock trunklid to have the mounts on the outer edges. For efficiency purposes, the uprights should be thin and parallel to eachother -but this is insignificant in the grand scheme of things for most people. Quote:
http://bigmike.marlincrawler.com/for...php?topic=33.0 http://nzhondas.com/pub/112100-inter...road-cars.html How much do you track your car? What tires are you using? I like the cup wing, and while cool on a track, it might stick out as 'boy-racer' on the street. Then again, while the RS's wing is more 'streetable', it's still very bold. Then again, it's a GT3 so it's justified either way. I think the RS wing is the best value unless there's a different manufacturer out there with a similar wing as a Cup car which should cost less than half of that $8K figure. Last edited by Billj747; 10-29-2013 at 10:29 AM.. |
10-29-2013, 04:19 PM | #14 | |
Rep 898
10-29-2013, 05:36 PM | #15 | |
Rep 658
10-29-2013, 08:13 PM | #16 |
Rep 8,077
I know a couple who has a 996 GT3RS and they actually prefer the less aggressive wing and front lip. The bigger stuff (cup wing and lip???) made the car understeer more than they liked...but this couple are a little crazy as well...
This is all second hand info though. I don't drive Porsches.
