Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Exterior / Cosmetic Parts (External and Internal) & Lighting
      06-13-2019, 08:59 AM   #1
Nate@IND
Nate@IND's Avatar
2868
Drives: BMW
RKP E92/93 M3 Carbon Kevlar hood
If you’re on a mission to make your BMW as lightweight as possible, this Carbon Race Hood from RKP is the solution. By swapping the factory composite or aluminum panels, RKP is able to rework the factory underside skeleton, as well as use a foam hex cell core in the panel’s inner construction to produce a lightweight yet rigid structure. This formula yields a strong yet light hood with a 40% weight savings that’s as at home on the street as it is on the road circuit. Best of all, this part looks just as good as it handles, giving you a BMW that is an all around rockstar.
https://ind-distribution.com/product...rbon-race-hood
Features:
Full carbon composite construction by dry laid carbon and resin infusion.
Weighs only 13.6 lbs ( OEM is 22.8 lbs. )
Designed and made in the USA
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
