07-20-2018, 03:58 PM | #1 |
Rep 7,101
Sudden oil consumption after RB replacement
Hi guys,
as mentioned here (https://www.m3post.com/forums/showth...253084&page=34) I had my rod bearings replaced. My engine have never consumed a measurable drop oil between 5k oil changes over 26k miles. On my way down from the shop (230 miles) it suddenly did. Nothing alarming and need to work out details overtime but maybe in the range of 0.3-0-4 liter. I measured both with Carly (which gives a better resolution when it drops) and the cluster. Bit more the first hour to slow down as it seemed. The oil is the same Shell 10W60 I always used (this was called "Supercar" but speced for M cars etc). 9 liter was filled originally, showing half bar. I topped up when down to 1/4. The new bearngs (ACL HX) have more clearance. FWIF the temp was a tad lower (2-3C) on high way after the change which I thought was nice. I can't understand what the rod bearings should have to do at all with the oil consumption, maybe some of the experts can chime in on this? I also wonder if anybody else have noticed an increased oil consumption after RB replacement? UPDATE 27th July: After driving a few days the level seems to have stabilized. Hence you guys where right, after complete drain it takes a little while and top up. Will probably end up filling a good 9.7-9.8 liter to hit Max. Thanks Thanks! Last edited by Helmsman; 07-27-2018 at 10:16 AM.. |
07-20-2018, 04:17 PM | #2 |
Rep 10,601
If it was in the first 200 miles after an oil change , I would pay no attention since the sensor takes a while to read accurately. If you really are using 1L per 1000 miles you will know soon enough. That would be pretty high for street driving.
07-20-2018, 04:21 PM | #3 |
Rep 7,101
Thing is that I've done 5 changes since I got the car and it never consumed anything, I'm talking rock stable. Sensor has always been fine, reflecting a tad low filled while coming up straight after top up. It it a bit strange actually.
///M Power-Belgium63072.50 |
07-20-2018, 05:07 PM | #4 | |
General
63073
Rep 24,609
My oil level reading with 8.8 liter is at 80% . So your half bar , and down to 1/4 reading with 9 liter is/was actually pretty low .
07-20-2018, 05:30 PM | #5 |
Stop the hate, get a V8
3850
Rep 8,625
230 miles is not enough to indicate anything. If the level continues to fall over the next 1,000 miles, then maybe I'd say something is amiss.
Past: 2011.5 M3 sedan ZCP |
07-20-2018, 05:31 PM | #6 |
Rep 7,101
Phil, keep in mind the engine drains with the sump off for 24h. There is a tad more oil coming out then compared to a normal oil change. Read that 9.5l is fair after RB change. As we started at 9l flat I believe half bar (31.46 on Carly) is pretty accurat.
The surprise is that it all of a sudden fell from there. Ah well, lets see if some of guys that changes shells chime in. Cheers |
07-20-2018, 05:53 PM | #7 | |
General
63073
Rep 24,609
If your car is asking for oil again in the next 500/1000 miles . Something is wrong. Meanwhile I would drive it like usual . But keep an eye on it...
07-20-2018, 06:21 PM | #8 |
Rep 12,723
don't sweat it until after your next oil change. a bearing change doesn't touch anything that consumes oil.
MilehighM3914.00 |
07-20-2018, 09:52 PM | #9 | |
Rep 10,601
07-21-2018, 02:38 AM | #10 |
Rep 7,101
Cheers guys. Certainly aware of that the sensor can play trick but as mine has worked fine for years this made me wonder.
I'll enjoy my new bearings for a few days and report back. |
07-21-2018, 06:27 AM | #11 |
Rep 10,601
The oil fed to the bearings is recycled to the pan and pump pickup so I am having a hard time understanding how changing rod bearings affects oil consumption.
07-21-2018, 07:35 AM | #12 |
Rep 450
Helmsman maybe post this in the RB replacement thread to see if others have experienced the same.
07-21-2018, 08:31 AM | #13 | |
General
63073
Rep 24,609
07-21-2018, 08:54 AM | #14 | |
Rep 450
07-21-2018, 09:09 AM | #15 |
Rep 2,359
I use about 1L/1000km when I drive like an idiot. ~2000km if I baby it. Consumption rate interestingly was higher during highway driving.
Pass me if you can.
07-24-2018, 11:51 AM | #16 |
Rep 3,980
I've noticed some wanky readings after RB jobs, most cars bounce around a little before settling after a bit of driving. With the pan off more oil than normal comes out.
Continue to monitor it, but I doubt there is any cause for concern right now.
MilehighM3914.00 Scharbag2619.00 |
07-24-2018, 05:03 PM | #17 |
Rep 8,075
Drives: 11 E90 M3 Individual
I had to add some oil twice after rod bearings within the first 2k miles. Haven't had to add any since.
2018 F30 320iX Melbourne Red
07-27-2018, 06:15 AM | #19 |
Rep 7,101
Thanks |
07-27-2018, 08:24 AM | #20 |
Rep 8,075
Sounds about right.
