09-04-2018, 11:55 PM | #1 |
Rep 4
Crank but not start with error code 2756 (Solved)
2007 e92 m3
I had cylinder 2missfire issue recently and had change the coil and spark plug Drive to work normal this morning, but cannot start my car at noon Scan tool showed 2756 iginition cylinder 4 2758 iginition cylinder 7 2759 ignition cylinder 6 If I persist push start bottum to start my car Fault code increasing to all 8 cylinder Anybody knows what’s wrong ? Feul pump? Last edited by madcrazy; 09-13-2018 at 10:10 AM.. Reason: Car went down |
09-13-2018, 10:06 AM | #4 |
Rep 4
Turn out to be the F79 fuse burned
F79 Crankcase breather heating Oxygen sensor heating After change the fuse only the cylinder 4 error code 2756 remain so I check the ignition coil of cylinder 4 first the PLUG HOUSING (Mfg Part # 12527508154) of the ignitioncoil was burned out after change the PLUG HOUSING and F79 Fuse and Ignition Coil no problem with the start but still unknowing why the plug housing will burned out???? |
Theodore668.50 |
