05-20-2022, 03:59 PM | #1 |
Rep 36
Toyo R888R?
Looking for some info on fitting 295/30 R888R's on a 18x10.5 ET23 square setup for a E92, I've searched for a while and can't seem to find a tread that goes over these tires. If I can't do 295/30 then I'll go with 275/35 .
I plan on running FEAL 441+'s the spring rate might be 10k/6k but that could change depending on if I get custom spring rates. I don't mind having to do some stuff like removing the front fender liner or anything else. If anyone else has any other R-compound 295/30 tires to recommend I'll look into those also. |
05-20-2022, 04:14 PM | #2 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
https://www.m3post.com/forums/showthread.php?t=1916791 OR the Rub / No Rub Index thread: https://www.m3post.com/forums/showthread.php?t=522139
///M Power-Belgium63359.50 |
05-20-2022, 04:38 PM | #3 | |
Rep 36
DrFerry6728.50 |
05-21-2022, 10:43 AM | #5 |
Rep 36
From what I've read people have faster lap times with them compared to NT01's but they heat cycle faster? They are the only decently priced R compound in 295/30. That I can find.
nycplumber686.00 |
05-27-2022, 10:40 AM | #7 |
Rep 36
Yea I looked into them I think imma run Proxes RR in 275/35 and 295/30. They seem to do better then then the A052's and are better priced. Doesn't look like you can do anything to fit a 295 on the front.
