04-23-2022, 03:22 AM | #1 |
Rep 222
Wheel spec advice
Just keen to hear how below spec wheel/tyre combo would fit on a e90 M3?
Front: 9x19" ET 15, 245/35/19 Rear: 10x19" ET 25, 265/35/19 Thanks, J.
2010 E90 M3
2013 F31 328i Touring M Performance |
04-25-2022, 09:34 PM | #2 | |
Rep 129
You could probably go a little bit wider with the tyres if you wanted? 265 on a 10" rim is probably minimum before you compromise ride and kerb protection. Could also reduce the offset a few more mms on both sizes for a flush fitment.
2011 E92 M3 - Mineral White - Pure Edition I
04-26-2022, 07:14 AM | #3 |
Rep 1,230
The front is gonna be tight. It's less clearance than a M359 wheel with a 15mm spacer. Not ideal but it would probably work. If you plan to lower then I wouldn't go with this set up and look for something +21 on offset
04-26-2022, 02:47 PM | #4 |
Rep 222
My car is lowered so will give these a miss as I don't want to get in to issues with rubbing.
2010 E90 M3
05-26-2022, 09:25 AM | #5 |
Rep 1,083
You're fine with that spec.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
