02-08-2022, 08:58 AM | #1 |
Rep 2
19x9 et25, 19x11 et30 any issues?
I got an absolutely mental deal on a set of Advan ADV05 forged 3pc wheels which were set up on an E63 m6.
The fronts are 19x9 et25 and the rear is 19x11 et30; will I have any issues from a tcu/ecu and handling standpoint running these? I know it's not the most ideal setup, and I've never seen another owner running the same spec, but I have seen that 19x9 et25 fit and that 19x11 et30s fit. Also, would the fitment be alright with a set of Potenza 255/35/19 fronts and 295/30/19 rears? The tire height has an extremely minor discrepancy so I'm not concerned with the tires, I'm more-so concerned about rubbing. The car is a 2013 base model vert on stock ride height, but will be on lowering-springs soon. Any help is appreciated! Thanks in advance! |
02-08-2022, 10:04 AM | #2 | |
Rep 510
With that rear tire size you'll need to roll your fenders, rather heavily I might add. People run 18x10.5 sometimes, but even then you need to slightly roll the fender. Can you return them? -Duke |
02-08-2022, 03:27 PM | #3 |
Rep 1,047
I'm not so sure about that. Many people have run a 295 on the stock m359 wheels without spacers (although this is an inappropriate size for a 10" wheel), and had no issue at stock ZCP ride height.
I'm actually having 19x10+25s and 19x11+25s installed 275/30/r19 front 295/30/r19 rear on Thursday. Multiple reports say this should not rub on stock zcp suspension. I'll report back on thursday and confirm/deny if that is accurate. |
02-08-2022, 03:36 PM | #4 | |
Rep 510
On 19x11, they still might rub a bit on the back. -Duke |
02-08-2022, 03:41 PM | #5 |
Rep 1,047
Again- multiple reports that 19x11+25 with a 295/30 does not rub on ZCP suspension. Cannot speak to a +30 though. Will report back on Thursday to confirm/deny. Have a very interesting project finally wrapping up that I think alot of folks will be interested in.
02-08-2022, 03:43 PM | #6 |
Rep 674
I had 19x11 with 295/30/19 hankook v12 and it didnt rub at all on my e93. I forget the offset but it might have been +25
Im in h&r springs too You might actually need a spacer |
02-08-2022, 03:56 PM | #7 | |
Rep 510
-Duke |
02-08-2022, 04:10 PM | #9 |
Rep 674
https://www.m3post.com/forums/showthread.php?t=1132368
Here is an e93 with no rub too |
02-08-2022, 04:38 PM | #10 |
Rep 1,047
02-08-2022, 08:04 PM | #11 |
Rep 674
02-08-2022, 11:12 PM | #12 |
Rep 1,047
03-15-2022, 01:45 PM | #14 |
wannabe
252
Rep 819
18x11 final et30 with 295/35/18 and no rub out back.
The 19x11 et 30 with a 295/30/19 out back will be fine with a moderate drop and a touch of camber. The paint where the quarter and bumper meet is where you are likely to get a little touch if anything, easy enough to either trim the plastic liner away at that point or let it clearance itself.
E90 M3 - 6speed - slicktop - single hump
03-28-2022, 09:38 AM | #15 | |
Rep 2
I got around to mounting them this weekend and the fitment was perfect. No rubbing all around whatsoever. |
03-28-2022, 09:48 AM | #16 | ||
Rep 510
-Duke |
03-30-2022, 06:25 PM | #17 |
Rep 674
05-04-2022, 12:24 PM | #18 |
Rep 82
19x11 et30 will actually get you the most tire/clearance. You can easily run 295/30 with out rubbing. It’s the low offset like 21 that you can’t get away with meaty tires in the rear. I’m also running 19x11 pretty slammed on coils and don’t have any rub with 2 people in the back or during hard driving over dips etc. 100% those wheels will easily fit your car with out any fitment issues.
05-05-2022, 11:14 AM | #19 | |
Rep 13
Just picked up 19x11 et31 rears and plan on going 285/30/19. I'm on the MSS HAS kit so I can dial it in a bit (but not much). |
