09-30-2021, 10:57 AM | #1 |
Rep 25
What else should I address "While I'm in there"?
I'll be changing my fuel breather valve on my e90 due to the premature fueling stoppage, and I'll be changing the spark plugs while the intake manifold is off. Is there anything else I should address (sensors, hoses,...) while I have things apart?
09-30-2021, 12:45 PM | #3 |
Rep 25
My car has about 123,xxx miles, I purchased it just over a year ago with 112,xxx. So far I had the RBs replaced, and oil changes. I have not done the TAs just yet, I want to check them out when I pull the manifold.
09-30-2021, 01:29 PM | #4 | |
Rep 933
Drives: E90 M3
Carbon build up on the ITB flappers can also be addressed. Check for leaks around the valve covers while you're in there; any caked dirt/grime around the gasket area is a leak. vacuum/blow any crap that fell in the 'V'. You can also get a good look at the belts and accessories with the plenum off. Look for signs of oil filter housing leaks too. With higher mileage engines, it's a good idea to take some time to just look at everything under there for general condition. |
09-30-2021, 01:30 PM | #5 |
Rep 946
Well, certainly the TA's will fail at some point, but there is no real way to know without looking or waiting for them to go out. They are a pain to get to but it would be worth it to pull them out and take a look. If you see evidence of the gears beginning to come apart, its time to do them.
Idle control valves are also failure prone, but also rather pricey so likely better to wait on that to begin to fail. You also want to be careful working under there as most of the plastics will be hard and brittle, especially sensor plugs and tubing. BMW is one of the worst at plugs and such breaking after 10 years or so. I have owned over a dozen of them and I think nearly every one had something like that break during service. Granted they WERE all older and higher mileage when this happened, so YMMV. Good Luck!
09-30-2021, 02:26 PM | #8 |
Rep 724
You may want to get the hose that attaches to the breather valve. As the plastic ages removing the old hose was the hardest part of the job.
Besides throttle actuators, you may want to replace the thermostat too. Not hard once the plenums off. Also take a good look under the water pump, mine developed a leak around 140-150k miles. |
09-30-2021, 05:45 PM | #9 | |
Friends don't let friends ESS
3166
Rep 873
09-30-2021, 05:52 PM | #10 |
Rep 933
Drives: E90 M3
09-30-2021, 06:04 PM | #11 | |
Rep 933
Drives: E90 M3
tbuck1185.50 |
09-30-2021, 06:11 PM | #12 | |
Rep 946
Ajolives922.00 |
09-30-2021, 06:47 PM | #13 |
Rep 25
09-30-2021, 07:25 PM | #14 |
Rep 933
Drives: E90 M3
Looking good! I've got a soft spot for E36 M3s, they're so great.
09-30-2021, 08:22 PM | #15 |
Rep 946
I love the E36 M3, had 2 of them, and likely the best all around chassis BMW has ever made. If we had gotten the actual M3 engine it would have been something I might want to keep forever. We really got robbed on that one.
10-01-2021, 12:08 AM | #16 |
Rep 25
Couldn’t agree more! Although a S54 would work just fine in there for me.
10-01-2021, 06:47 AM | #17 |
mTekMods
2148
Rep 2,905
Push the throttle actuator arm with your finger, if it moves free and smooth youre fine. If you feel it getting hung up replace or rebuild.
10-01-2021, 10:33 AM | #19 |
09 M3 e93 VF650, e30 e85, Remus, Federal’s 595rs
205
Rep 329
You guys remove the plenum to do spark plugs ? Weird.
09 M3 E93 - VF650, AFD e30 e85, Remus Race, Federal’s 595 rs-pro’s.
10-01-2021, 04:07 PM | #20 |
Rep 946
Yeah, I see folks say that, and for the life of me I don't see why you would have to do that. It would make it a little easier to do the plugs, but add the time and effort to get the plenum off and I would say it is a wash.
10-02-2021, 05:34 PM | #21 | |
Rep 724
