03-05-2016, 08:54 PM | #1 |
Rep 287
Seatbelt Buttler
The driver side arm that hands over the seatbelt on the driver's side has stopped handing over the belt. The mechanism on the arm works. The passenger side also works perfectly fine. Nothing is broken but the belt skips.
Previously I used to iron the belt. The problem seems to go away temporarily but returns. I ended up ironing the belt more than what I did my cloths. Ironing doesn't do the trick anymore. Any other suggestions? |
03-06-2016, 02:10 AM | #3 | |
Rep 287
03-06-2016, 08:30 AM | #5 | |
Rep 287
03-06-2016, 10:13 AM | #6 |
Rep 1,171
I tried the spray on starch and iron approach but in the end just coded them out. They're a but noisy and slow so when the belt stopped grabbing, it was an easy call to retire them...
05-04-2016, 06:31 PM | #8 | |
Rep 46
Drives: 2010 BMW M3 e92 AW/FR DCT
I'll update it now, found an even better long-term solution. It doesn't fix the arm being flabby issue though, just the seat belt wear over time. |
05-04-2016, 08:58 PM | #9 |
Rep 1,171
Thanks for the solution but I'm confused by the video. It says placing the hairpin 2.25" below the hole in the car works... but then there's also talk of adjusting the buckle position... can you clarify please?
05-05-2016, 03:16 AM | #10 | |
Rep 46
Just try it out with the pin first, then remember the place where you put it and it worked, remove the pin. Move the buckle up the seatbelt and hold it with one hand, then re-insert pin around seat belt, let the buckle slowly glide down, it will stop at the pin. For me the buckle pretty much lines up with the trim line, maybe a bit above it, you need to tweak it a bit if the butler hits the buckle, it's too low. |
05-05-2016, 03:50 AM | #12 |
Rep 46
No worries mate, let me know how it works out, would love it if it's something that works for everybody.
05-05-2016, 03:23 PM | #14 |
Rep 46
