10-19-2022, 01:00 PM | #1 |
Rep 149
Drives: BMW M3 E92
Broken diff bolt problem after problem
I’ve had bad wheel hop for a while. I broke my differential mount clean in half once, 3 hours from home…
About 3 weeks later my diff bolt broke, it’s was one in the back. Took it to a shop and they had it replaced. Now, about two months later, my diff bolt broke AGAIN. I went and tried to replace my subframe with new diff and subframe bushings (which I was way over my head about, I took half of it apart and put it back together). Said screw it but I did check the diff bolt out. Is there any easy-ish way to remove the nut side of the bolt? Also why is this such a big problem for me? I do a rolling launch here and there, I’m not doing digs or racing/tracking. Hopefully the poly bushings help out the wheel wobble and stabilize the subframe and diff. And I called a shop and they quoted 6k, with a new subframe. I sourced a used subframe and had a friend install the bushings on it at hyundai for free. So he said the labor would be 2-3k. Does this sound right? It’s delta V in Richmond VA. If there’s a better shop let me know. “The shop” in Richmond said it wasn’t something they’d get in to… I’m still driving the car, it’s my only car, and it’s fine. Subframes already bent, and as long as I don’t hit the throttle, gas SLIGHTLY too hard or shift poorly it doesn’t move the subframe/diff at all. I can feel a big knock if it moves. Last edited by Winter.M3; 10-19-2022 at 01:10 PM.. Reason: Extra info, added pictures |
10-26-2022, 08:54 PM | #3 |
Rep 10,610
I did not change the subframe but I did DIY the diff and subframe bushings. I was able to lower enough for that work without removing it entirely. You will have to drop it. Disconnect the short brake lines that are enough trouble many don’t replace when doing braided lines, the diff input and axle stubs, and suspension arms and all brake/sensor/diff wiring. Maybe use a 2 stage trans Jack with supporting brackets or a friend or 2 to lower the subframe with diff. Then swap and reinstall. Not easy but not $2-3k if you DIY.
10-26-2022, 09:07 PM | #4 |
Lord Scrip
1812
Rep 3,013
Drives: 2011 M3 Coupe
Is it the launching or are you hitting your diff on shit? There's some pretty bad scrapes on the bottom of your diff fins. I'm not sure how that happened because I'm pretty low myself out here in the shitty Cali roads and I have zero scratches on my diff. I also have 240,XXX miles. Do you Jack the car up by the diff? I understand there is a valid spot in front of the fins but I still would never do that.
10-27-2022, 05:24 AM | #5 | |
mTekMods
2139
Rep 2,898
the bolt is bent inside the bushing its not going to want to come out. you need to apply force to it while you turn it. put diff bushings into the new subframe before you install it or you'll be back here again with the same problems. make sure the threads on the differential arent damaged either.
11-02-2022, 10:58 PM | #7 | |
Rep 149
Drives: BMW M3 E92
11-02-2022, 10:59 PM | #8 | |
Rep 149
Drives: BMW M3 E92
11-02-2022, 11:06 PM | #9 | |
Rep 149
Drives: BMW M3 E92
How was taking the bushings out? My friend who works at a Hyundai dealership took my subframe and put in 5/7 bushings but couldn't get the front ones off. NO ONE in the whole shop had a cup that fit on the bushing to press it out. I just bought a kit that should be able to take it out. I know I probably could've found something to DIY it but this will be easy... I've been driving with it broken for weeks. |
11-02-2022, 11:10 PM | #10 | |
Rep 149
Drives: BMW M3 E92
I know for a fact I have hit my diff on the floor on backroads, but that was my old diff... which sheared clean in half like I mentioned. This diff casing was bought used, I don't think I caused those scratches. I've only jacked it up from the diff once- to do this DIY. |
11-02-2022, 11:15 PM | #11 | |
Rep 149
Drives: BMW M3 E92
I went with 75d (black) bushings from akg. Should solve the problem I hope. |
11-03-2022, 05:11 AM | #12 | |
mTekMods
2139
Rep 2,898
the subframe bushings are easy with the right tool. the diff bushings I used a circular saw blade fully circle shaped and it fit right over the diff bushing housing then a long threaded rod oiled with a combination of washers and nuts. just run it up past hand tight and then pull it out by turning the nut on the backside of the circular saw tool.
Winter.M356.50 |
11-06-2022, 10:47 PM | #13 | |
Rep 149
Drives: BMW M3 E92
I got the rear (front) bushings out yesterday. 3 1/8 hole saw fit right over it and pulled it out. The diff bushings and rear (rear) bushings my friend said came right out with a ball joint puller. |
11-07-2022, 05:04 AM | #14 |
Rep 6,635
Solid subframe bushings and solid or harder than OEM diff bushings (purple) should remove wheel hop.
11-07-2022, 06:09 AM | #15 | |
Rep 10,610
I think some or all of the bushings are pressed in from the top so you cannot pull through from the bottom or maybe it is the other way around. There is a flange around one end of the bushing that will let you pull it in only one direction … unless you break off that flange. 3 pieces of long threaded rod like a 1 meter piece cut in 3 will let you lower the subframe further without dropping it completely. The driveshaft and axles can stay connected to the diff within a limited range of motion but it is enough. There are various wires that must be disconnected. I did this about 6 years ago so I can’t remember everything. Most shops just drop the diff for better access and that may be the best way. Parking brakes can be disconnected under the handle as I recall though it can also be done under the rotor if you prefer. |
Winter.M356.50 |
11-07-2022, 06:13 PM | #16 |
Rep 149
Drives: BMW M3 E92
I tried from the rotor. Every source that I saw said you have to take out the whole center console to reach the ebrake lines. I didn't want to bother. Just got an appointment at the shop! Hope the bushings make it more fun to drive.
11-23-2022, 09:15 PM | #17 |
Rep 23
Did you get the subframe/bushings installed? I want to do the same thing with my subframe this winter as my car feels like it settles into turns twice when I was at VIR this year. I'm sure my rubber bushings are clapped. How does it feel?
