02-14-2021, 01:05 PM | #1 |
Rep 361
Bilstein B16 coilovers and endlinks
I am in the process of installing B16 damptronic coilovers on my E92. I'm running the fronts at the default setting which is about 3 threads from the lowest, which I believe is about 1.2" lower than stock.
Can anyone else running this same setup speak to your endlink setup? Are you running OEM or did you go aftermarket? If so, what brand and length did you go with? Thanks Last edited by wootloops; 02-14-2021 at 02:06 PM.. |
02-16-2021, 02:30 PM | #2 |
Rep 580
Following. About to install mine too, thanks in advance
Current - 2011 E90 M3, Jet Black, 6MT ZCP. Recaro/Bilstein/BBS/StopTech/Haimus/Turner/Pinnacle/BE/Auto Solutions/Macht Schnell/GC/Whiteline/Slon/Alpine
Sold - 2008 E92 M3, AW x FR, 6MT. CF roof is oh-so-Sexy! IG @misterclutch888 Slow Build |
02-19-2021, 03:54 PM | #4 |
Save the manuals!
6015
Rep 6,746
It's designed to re-use stock endlinks. I stuck with OEM.
wootloops355.00 MisterClutch888552.00 |
03-17-2021, 11:18 AM | #5 |
Rep 130
I'm going from the ground control coilover sleeve kit (which included end links and camber plates) to the Bilstein B16. I'm going to use the Vorshlag Camber Plates OEM Perches (Strut Style Bilstein PSS10).
Is there an aftermarket endlink that you would recommend for street/daily driving use? |
