01-01-2021, 11:55 AM | #1 |
Rep 940
Hey team,
My steering wheel makes a strange noise while cold (approx. 45F and below). After about 30 min of driving the noise goes away. Is this something I should worry about?
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
01-05-2021, 05:21 AM | #3 |
Rep 66
in my experience i would be checking the strut top mounts in the front. i have taken the caps off and put grease in but will eventually come back. other than that would recommend using a drive on lift so someone can be underneath to pin point if its a control arm/ ball joint
01-05-2021, 05:35 PM | #6 |
Rep 940
Yes. I had a shop instal my eibach springs after I failed.
2013 e92 M3
01-05-2021, 07:49 PM | #8 |
Rep 79
Drives: 11 E92 m3 6mt
*Subscribed* mine is doing the same thing on cold mornings then goes away. Would like to know what fixes yours.
01-05-2021, 08:44 PM | #9 |
Rep 940
No noise before or after the springs were installed. The noise started when the temps here fell below 45F. This is my first winter with the car.
2013 e92 M3
01-08-2021, 07:48 PM | #10 |
Rep 191
That's a strange noise. I used to see a lot of e9x vehicles with a squeaking/rubbing noise when turning the steering wheel. It was actually pretty common. Hard to tell from you're video but the fix was to lubricate the small plastic bearing that is in the boot at the firewall that the steering shaft goes through. Take off the panel above you're pedals and you can see it where the steering shaft goes into the boot. Silicone spray lube works well. Worth a try and won't cost you anything.
DL335D580.00 |
01-17-2021, 09:01 PM | #11 |
Rep 940
The shop told me that my upper strut mounts are badly worn and that's what's causing the steering noise. Car has 50k miles, seems like they should last longer.
2013 e92 M3
01-18-2021, 12:37 AM | #12 |
Rep 619
I had this issue a while back. It seems that the steering rack gets dried up in the cold and so I put a bit of grease on it. You can try doing it from under the kick panel or from under the car.
I ended up having the bushing replaced by BMW but it was under warranty |
DL335D580.00 |
01-27-2021, 07:46 PM | #13 |
Rep 940
So it was the upper strut mounts. The tech said they were cracked and the bearing were in really bad shape. The front suspension feels so much better now. Before it would crash over large bumps, but now it's smooth as silk...well sort of.
2013 e92 M3
