01-16-2018, 09:26 PM | #1 | |
Rep 11,667
Rogue Engineering 14mm Wheel Stud Jig
Has anyone done the conversion to 14mm wheel studs??
R.Eng. has a jig for drilling the hubs and re-tapping to accept 14mm Studs. http://www.rogueengineering.com/Rogu...Jig_p_265.html Quote:
Some of them may be a maintenance issue (too old) But, I know of several that were well within the usage window, and should not have failed. I need new studs now anyway, seems like a good upgrade while I'm at it. It would be interesting to hear if anyone has used this jig kit.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 01-16-2018 at 09:48 PM.. |
01-16-2018, 10:22 PM | #2 |
Rep 12,757
i think a lot of people screw with their studs too often... i see tons of people clicking away with a torque wrench after every session after they come in and the hardware is the hottest. torque them at the beginning of the day and be done with it. once they heat up, they expand, people torque them, then they cool down, and they can't contract correctly.
studs are said to have a two year service life, and sometimes people aren't proactive. has anyone ever had a nut fly off a stud because it became loose after a few sessions?
chamba002238.50 |
01-16-2018, 11:17 PM | #3 | |
Rep 1,848
scotty_miller185.50 |
01-17-2018, 07:58 AM | #4 |
Rep 11,667
Yeah, I see that a lot too.
I torque at the start of day , cold, and that's it.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 01-17-2018 at 04:06 PM.. |
01-17-2018, 09:23 AM | #5 |
Rep 11,065
I think the 14mm conversion is a great idea but I just bought new 12mm studs so I’ll think about it in a few years.
M3 Number 863232.00 |
01-17-2018, 02:48 PM | #6 |
Rep 2,812
Drives: '09 E90 M3 - IB
It's very cool to find out that something like this is available now.
Bummer that I just replaced my 12mm studs on Sunday...... Maybe next year! |
01-17-2018, 04:05 PM | #7 |
Rep 11,667
Looks like I may be the Guinea pig on this....
It will be a month or two before I get to it, but I'll post my results when I do.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
01-17-2018, 04:58 PM | #8 |
Rep 2,812
I called Rogue Engineering today and asked them about this tool. They said they decided to create it after several race teams that they work with had been running the 14mm mod successfully for several seasons.
I had looked into this a couple years ago when I was breaking studs on a regular basis. Jordan Yost did this mod on his own to his E92 M3 race car successfully, so I had been chatting with him about it. (They did the mod without a handy tool set like this.) For sure, the front hub looks fine for expanding the holes. The hub flange has plenty of room on the outside edge of the holes. But the rear hub flange is a smaller diameter. If you expand the rear holes, they're gonna get pretty close to the edge of the hub flange. Jordan and the Rogue Engineering guys all say it's ok. So I guess I believe them, but it is a bit scary to look at on the rears. Honestly, the topic has moved to the back burner for me since I moved to the Bimmerworld Premium Race Bullet Nose Stud at $10 a piece. ( http://www.bimmerworld.com/Wheels-Ti...BoC3cgQAvD_BwE ). With regular track use, I have not broken anymore studs since I began using them. And I usually change wheels 3 or 4 times per track day (either rotating or changing wheel sets), so I'm not gentle on them. The steel is a harder 12.9 steel (vs most studs using 10.9 steel) and they have a unique shoulder on them that sits flat on the hub flange helping to distribute the stress. It's been working fine for me. Perhaps next year, I'll try moving up to 14mm on just the fronts since all but one of my broken studs were on the front. (And then I'll sit there and wonder if I have the balls to do the mod on the rear hubs....) Good luck! I'll be very curious to hear how it goes! The Rogue Engineering guy said the instructions are pretty detailed because there's a very specific set of steps and an order that it has to be done. Also, you have to drill out the rotor hats to accommodate the larger diameter stud, and I guess we're on our own for that part......yikes! hahahaha |
inTgr8r2443.50 SYT_Shadow11736.00 |
01-17-2018, 05:04 PM | #9 |
Rep 11,667
Thanks...
I'll check out the rear hubs, before I head down this road.
01-18-2018, 07:03 AM | #10 |
Rep 11,065
The Bimmerworld studs look nice. Others have gone to a bigger flange at the base as well. I like the fact that they are made in the US though Germany would be fine also. The great thing about Bimmerworld for a part like this is that they race what they sell so it’s a tested product. Obviously that does not apply to all their parts.
Senpai484.00 |
01-18-2018, 09:31 AM | #11 |
Rep 11,667
Yeah, I like the specs of the BW ones as well.
I've been using Turner's so far, and have not had any failures, but these look even better. I have seen failures on the 'others' with similar shanks.
01-18-2018, 10:08 AM | #12 |
Rep 12,757
looks like they have aluminum lug nuts... thats kinda cool.
another thing i'm thinking about with larger studs is; does that mean the nuts are larger? then you might have to locate a thin-walled socket to fit certain wheels.
inTgr8r2443.50 |
01-18-2018, 01:42 PM | #13 |
Rep 11,667
^good point.
01-18-2018, 01:48 PM | #14 |
Rep 2,812
You still use a 17mm lug nut. You still use your same wheels. The lug nut still seats the same way in your wheels. Nothing changes there. The inside of the lug nut is just 14mm to accommodate the larger diameter stud.
roastbeef11648.50 |
01-18-2018, 02:02 PM | #15 | |
Rep 11,667
The holes are 14.25mm, so they should be OK. Of course this will vary depending on which hats people have.
01-18-2018, 02:15 PM | #16 | |
Rep 1,171
Thanks! |
01-18-2018, 02:56 PM | #17 | |
Rep 11,667
Plus when you buy them you will get instructions specific to the product. e.g. from Turner https://1c2a8a2161d644d95009-22d26b3...structions.pdf
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 01-18-2018 at 03:01 PM.. |
01-18-2018, 03:08 PM | #18 | |
Rep 2,812
hehe I couldn't stand myself. I got my 9668 kit and they were on the car the next day. Interesting to hear that the diameter is 14.25mm. Maybe nothing needs to be done. That would be very nice! |
01-18-2018, 03:17 PM | #19 | |
Rep 11,667
The Z4MC is currently occupying the heated bay and in the process of demodding. In the mean time the pile of M3 parts waiting for installation is growing.....
01-18-2018, 05:34 PM | #20 | |
Rep 2,812
The Bimmerworld stud: My method: -Remove the old studs. I use this tool which can take all 20 studs out in less than 10 minutes with an impact gun. https://www.amazon.com/gp/product/B00265M8N4/ -I put a decent amount of effort into cleaning the threads once the old studs are removed. I run a thread chaser (oiled up with WD40) through there, then degrease with Brake Kleener, and even swab a Q-tip with alcohol into each hole to make sure it's clean and dry.. -I use one drop of Blue Loctite. Red Loctite makes it EXTREMELY difficult to get the stud out of the hub if it breaks off inside the hub. The Bimmerworld stud comes with a pink, dry-crusted thread-locker. No one at Bimmerworld could tell me how it compares to Loctite in terms of strength, so I scrape all that stuff off and just use my trusted Blue Loctite. -I torque the studs onto the hub at 40 ft lbs. (Torquing a stud to 40 ft lbs is challenging. My impact gun is not powerful enough to jam the nuts together hard enough to allow me to torque the studs to 40 ft lbs. And trying to double-nut that much ft lbs manually is very hard when the stud is in the hub. I came up with my own way of double-nutting the studs before I put the studs in the hub.) -I torque my lug nuts onto the wheel at 80 ft lbs. With this humble method, I don't break studs anymore. |
msan414.50 |
01-18-2018, 06:35 PM | #21 |
Rep 11,667
One of the things I really like on the BW studs is the undercut at the base of the collar preventing thread bind.
I think this is a BIG reason for minimizing stress risers.
05-10-2018, 11:00 AM | #22 | |
Rep 1,077
Did anyone end up doing the 14mm conversion with this kit? I am building an E46 track car and am interested in hearing from someone who did the conversion (on an e46 or e90) before jumping in. Thanks! |
