06-01-2022, 05:11 PM | #1 |
Boost
1355
Rep 3,695
Drives: 135i M-Sport
Metal "tap" noise when letting off throttle?
I know most of y'all have upgraded rear suspension bushings so I figured that I'd ask here...
My new track car has almost 99k miles and I've noticed a very slight metal "clank/tap" noise occasionally when I go on / off throttle at low speed. Almost sounds like a diff with excess backlash or a diff twisting and tapping the subframe mount locations when the car goes on/off load. I'm assuming it's the diff bushings or maybe Guibo... Haven't had any issues after a couple track days and it hasn't gotten worse after ~1k miles and 2 events. Anyone here have similar issues in the past that were solved with new bushings? I have some powerflex diff bushings but likely won't have time to install them before the track this weekend.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
06-01-2022, 05:25 PM | #2 |
Rep 940
I had the same noise and a new center support bearing fixed it. Maybe it's time for a CF driveshaft. Fresh diff bushings could never hurt either. Solid subframe bushings are a must as well.
06-01-2022, 05:27 PM | #3 | |
Boost
1355
Rep 3,695
I have solid subframe bushings but haven't had time to do much else in the rear yet as I just picked up the car like 6 weeks ago.
06-01-2022, 05:30 PM | #4 | ||
Rep 940
Yeah definitely check for lash in the driveshaft. If the center support bearing is excessively worn it should be easy to spot. |
06-01-2022, 10:12 PM | #5 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
Or, alternatively, search the Forums using the term "cowbell"…
Davisca4552207.50 ///M Power-Belgium64189.50 |
06-01-2022, 10:15 PM | #6 |
Boost
1355
Rep 3,695
Haha yep, I learned a new word for the sound I'm hearing (cowbell).... I'm fairly certain it's the center bearing after lurking some threads and videos.
Thanks for pointing me in the right direction guys!
DrFerry6731.50 Davisca4552207.50 |
