06-03-2020, 09:28 PM | #1 |
Rep 73
Dead Key Fobs - Cannot Unlock with Button or Comfort Access
Anyone have any experience with dead key fobs? Car will not respond when pressing buttons on either key fob, nor will it unlock or start with comfort access. The key fob must be inserted in the slot for the car to start. Locks still work with central locking button. It is not the diversity antenna (swapped with a known working unit).
I've scoured ISTA and nothing is jumping out as the problem. I'm leaning toward a bad fuse, 2 bad key fobs, or something off the wall that I am not connecting. Strangely enough I noticed the problem begin at the same time I had a DCT fault (caused by a fuse). Anyone experience this? |
06-04-2020, 11:41 AM | #4 |
Rep 224
I'm chasing this same issue (E93). My key fob had terrible range and the comfort access took several attempts at the door handle action to respond. It seemed to get worse over the course of a year and then it finally stopped. At this point I have to use the metal key to lock/unlock doors and the key inserted in the dash to start. Over the course of the year I changed the key fob battery (CR2032) a couple of times. Neither of my key fobs will work at this point even with new batteries. I've checked all the fuses, all the way to the point of removing and confirming continuity and power to the fuse slots. I've reset by removing the battery terminal overnight and tried the fob re-sync procedure. Everything now points to a bad antenna. Mine is in the rear-view mirror (E93) and it seems I need a new mirror. Although I can't help but think I'm throwing parts at it rather than having a real diagnosis. A new mirror is a $400 buy and finding a used, specifically from an E93 (including the antenna), isn't easy with inaccurate descriptions.
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
09-07-2021, 09:20 PM | #7 |
Rep 254
Put a small piece of foam between the battery and the backing, BMW literally charged me $180 to do this shit for troubleshooting!!!
E90 ///M3 Silverstone II '11 (current)
E90 ///M3 Silverstone II '08 E46 ///M3 Alpine White III E36 ///M3 Arctic Silver E46 ///M3 Carbon Schwartz |
09-08-2021, 11:17 AM | #8 | |
Rep 684
