10-06-2020, 09:18 AM | #1 |
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
Please help: coding new SMC headlight module
Hi,
I have a new installation of bmw tools, and a good working cable ( I can read with this cable with INPA, and also programmed my 335i many times using MHD on the phone). I am trying to program the new headlight I installed into my 2009 M3 coupe (long story short, had to replace complete headlight) so the automatic headlight control stops popping up errors and beeping at me.. Its' a unit from another E92 bmw, not sure what year, but identical to what I had. I get "error in cabd! SG antworted nicht FRM_87, ID_SMC_lessen: ERROR_ECU_BUSY_REPEAT_REQUEST" Which seems to be pointing to the SMC coming back to the FRM with "ecu busy". Have you seen this before, could it be a faulty SMC module in this headlight ? I am using NCSexpert 4.01 and the e89 daten files which I downloaded together from bimmergeeks.net/downloads. At this stage I gave up and ordered another smc module on ebay, coming from a similar car, same part number, I plan to replace it and try again... Please let me know if you have seen this or have any idea what to try. The current headlight is like new, from a car which was totaled on the rear, so front was untouched. Thanks |
10-08-2020, 09:08 PM | #2 |
Rep 650
well, for what it's worth, it worked. I used NCSexpert and SG_Codieren job, and it worked. The module was fried though; I bought a new one on Ebay for 35 bucks (china made) , and it worked like a charm. Both my headlights now move and I have the side cornering light coming up when you turn the wheel more ...
the error was due to the module being .. obviously busy, as it was not there. |
10-21-2020, 06:54 AM | #3 |
mTekMods
2157
Rep 2,909
its usually easier to scan the module with ncs identify what the prg is then use tool32, write the vin with the checksum
