02-15-2011, 04:07 AM | #1 |
Engineer
Rep 18
E92 M3 LCI 2010 "M Key" settings
This is for Australian E90/E92 LCI spec (M Drive option and Comfort Access option); the rest of world models may have similar. The later LCI M3 (2011 spec for USA) has an additional menu (iDrive extra right push) after the "M Drive" menu screen called "M Key" setting. It allows you to setup the start default settings for when you unlock the car using Comfort Access (keyless entry). There's a limited number of settings you can play with; i.e. Power (Normal or Sport), EDC (Comfort, Normal, Sport), and Shift Lights (On or Off). It allows me to have a default whenever I unlock the car despite whether I changed a few settings during my last drive. I like this feature a lot and default my EDC to Normal, Power to Sport, and Shift Lights On. When I come across a twisty bit of road, I can then hit my M Drive button to toggle easily between my M Key default and my M Drive settings. I thought I'd post this to assist other owners with the feature; I appear to be discovering more of its capability each week. The trick to get this to program properly for those with the feature is you need to have the key inserted into the dash key socket to pre-program; there after, you can leave the key in your pocket and use Comfort Access as normal and have your "M Key" settings stored for next unlock and restart. It does not program on initial set up with key in your pocket. It's not in the user manuals, and the dealer had to look it up. Hope this helps others.
02-15-2011, 05:10 AM | #2 | |
Rep 2,528
"But resist we much; we must; and we will much; about that be committed." ~Rev. Al Sharpton 2010 E92 M3|Silverstone II|M-DCT|NCSW|2MT|ZCW|ZPP|ZTP|302|507|Gas Guzzler Tax |
02-15-2011, 05:45 AM | #3 | |
Rep 4,381
Also if your wife drives your car you can set all her preferences on her key....which will add to her nonprogrammable but saved key settings such as seat position etc...(I'm not sure which per user settings are held in the key besides seat position but its probably things like radio stations, heating etc) |
02-15-2011, 06:26 AM | #4 |
Rep 108
I like this feature, it ensures your default setting is used evey time you start the car. I also like power set to sport and edc on comfort. Pity there isnt an option for the auto start/stop, will have to go to the dealer to get that default permanently changed.
2011 E90 M3 6MT |
02-15-2011, 08:53 AM | #5 |
octane chick
79
Rep 1,187
Drives: ex-M
Interesting. I'm going to try this today.
02-15-2011, 09:03 AM | #6 |
Rep 939
Drives: 2024 M4 Convertible
Can I set the car to "remain locked" when my wife approaches with her key?
————————————————————————————————————— 2024 Tanzanite Blue II M4 Convertible |
02-15-2011, 09:13 AM | #7 |
Rep 2,528
HAHAHAHAHAH
02-15-2011, 11:00 AM | #8 |
BEAST
Rep 152
Better yet can it be programmed to have the car start,drive away and hide around the corner by itself when the wife approaches or possibly get it to act like the battery is dead and wont start in the same scenario.
02-15-2011, 02:25 PM | #9 |
octane chick
79
Rep 1,187
Drives: ex-M
I misread the original post. Already found the M Key settings. They are documented in the manual … or perhaps the supplementary manual. That's how I had found them in the first place.
02-15-2011, 02:30 PM | #10 |
Rep 567
I did not need to insert my key fob to program the "M Key setting". I have configured it many times without inserting the key fob and it remembers my default startup mode.
02-15-2011, 02:31 PM | #11 |
Rep 543
02-15-2011, 02:55 PM | #12 | |
Rep 939
Haven't needed 'em since.
02-15-2011, 02:58 PM | #13 |
Rep 543
02-15-2011, 02:58 PM | #14 |
Rep 15,818
funny my girls are too scared to even turn the car on.. let alone drive it lol
02-15-2011, 03:01 PM | #15 | |
Rep 939
They also handle a Glock .40 like a pro.
02-15-2011, 03:11 PM | #16 |
Rep 2,464
OP, thanks, I should try these. I like the way car starts by default (steering: normal, power: normal, edc: comfort, dct: s3). But then I'm still getting used to to the car. It'll be at least useful to set the shift lights to be 'on' even not in m-drive mode.
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
