      10-05-2018, 11:53 PM   #1
Danger-Zone
Mmmm3
Danger-Zone's Avatar
Drives: '08 E93 M3 DCT
E93 Squeaks and Rattles
I've searched the "rattles" forums and majority of the interior rattle I read about come somewhere from the dash. While I'm certain I probably have those rattles too, especially on unsmooth surfaces, the main squeak/rattle I've recently had pop up, comes from somewhere in the back (inside). I notice this faint little squeak coming somewhere from rear passenger side... it occasionally occurs under early acceleration (assumption is possibly from the vibration of exhaust, resulting in something inside squeaking from said vibration)
I don't know if it's just something with the convertible equipment or not. The Convertible top works fine, but maybe there's something that needs to be lubricated??
Another little rattle or I'd call it a "creak" from inside near the rear sears, typicallly occurs when there's a passenger sitting in the back and I'm going over unsmooth surfaces. It's an occasional creak and rattle. Just a little bothersome but not bad.
Are there any E93 owners out there who can elaborate on the common squeaks and rattles you've come across and how you dealt with them?
Thanks. Zilllion!
DZ
That?s How You Get Ants!!!
      10-06-2018, 02:30 AM   #2
WickedE93
Drives: White E93 M3
Thanks. Zilllion!
DZ
https://www.amazon.com/nextzett-9148.../dp/B004B8GTQG
Thank me later.
Treat it like franks red hot and put that sh*t on everything that's rubber.
Gintani Supercharger/ Gintani x-pipe/ Challenge rear muffler section powder coated black/ Alpine DCT Tune & Coding/ Republic Werkz modded headlights and tail lights/ Gloss black cosmetics, hood vents, and mirror caps/ Piano Black interior trim, Roof painted black by Ranz Motorsports/ Velos Designwerkz Solo V's/ KW V3's/ MRF Solid sub-frame bushings W/ Delrin Diff bushings/ Duke Dynamics CSL Trunk/ Euro bumper/ Full Dinmann aero kit.
      10-06-2018, 10:27 AM   #3
wfdeacon88
Drives: E90 M3
Thanks. Zilllion!
DZ
wow, crazy I was about to post the same thing .. my E90 had similar creaking noises from the year end, inside, when going over uneven surfaces. I couldn't tell if it was the windows or doors...
      10-06-2018, 03:10 PM   #4
Danger-Zone
Mmmm3
Thanks. Zilllion!
DZ
Thank me later.
Sweeeet! Thanks a million
      10-07-2018, 09:22 PM   #5
wfdeacon88
Drives: E90 M3
Thanks. Zilllion!
DZ
Thank me later.
Is this sound, and your recommended remedy, specific to the e93? trying to figure out if my E90 is the same thing... where exactly do you apply this on yours?
      10-08-2018, 12:25 PM   #6
WickedE93
It should work on any rubber that has gotten stiff from age or weathering. The E93 has a lot more and it works wonders and if you're having a similar issue to what we experience on our cars it should remedy your issue as well.
      10-10-2018, 10:11 PM   #7
Danger-Zone
Mmmm3
I ordered mine. Looks fairly simple, just squeeze bottle and let foam applicator fill with the liquid/chemical and then wipe on the rubber parts.
The top as a good amount of the rubber. Should I coat the seals in between the 3 layered hard top? I imagine the answer is Yes! Lol.
What about the plastic components that also may be culprits? It's hard to identify the tiny little creaks and ticks. It's not bad, but I notice things when it's silent in the car and I happen to traverse pavement that isn't very "paved"
      11-16-2018, 08:16 PM   #8
gearhead888
gearhead888's Avatar
33
Drives: e93 M3
I just treated mine this evening with the Sonax GummiPfleger, I needed to restock on Sonax wheel cleaner so I figured might as well try theirs...they make some amazing products!
Ill report back on the seals in a few days!
Anyone else hear a loud pop when initially opening their E93 top?
