06-21-2023, 05:06 PM | #1 |
Rep 332
Discussion - Is EDC obsolete?
My stock EDC dampers are going, and while I really want to maintain EDC function, most of what I read here seems to favor non-EDC options. For both performance AND comfort.
Yes, there are some great EDC options from Bilstein (and others) that have very positive reviews, but I am being left to ask: what's the point? Correct me if I am wrong but, EDC adjusts the compression stiffness of the damper. Does it also adjust rebound? Preload? From my understanding, those three should be adjusted together to reach ideal settings, is that correct? (is that what "wheel rate" is?) I am not here to bash EDC. Like I said, I would love to retain it. I think it's "cool" to have it be adjustable from the driver's seat. But does it makes sense to? Especially when options like Ohlins R&T seem to provide the best of both worlds. Looking to open this up for discussion...your thoughts? Some background: My car is mostly street driven, and roads in Oakland aren't ideal. I do maybe 2 HPDE days per year, but I am not going for fastest lap, just for fun and practice. Maintaining OE-level comfort (or better?) is more of the goal here. I say that because I know even the most comfortable aftermarket option is still sporty enough for canyon roads. Also, while I am not limited by budget, I would not want something overkill.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
06-21-2023, 05:45 PM | #2 |
Rep 1,939
I just purchased a set of none EDC Bilstein B4 for my 200k M3 for $400 from Rock Auto.
I am in the same boat as you, I want my car to drive nice and be comfortable. For $400 I am going to give these a shot and if they do not end up lasting I will get a set of $1800 B6 Damptronic shocks. Update: I canceled my B4 order and ordered B6s for $700. After reading some more technical documents I think they are worth the additional $300. Plus they are Bilstein yellow for the clout. Last edited by Nickco43; 06-21-2023 at 07:13 PM.. |
GiorgioE82309.50 |
06-21-2023, 05:45 PM | #3 |
Rep 4,341
TracTive Touring suspension. Best of both worlds. Works seamlessly with EDC, nearly as comfortable as Ohlins, and better body control than both.
DrFerry6748.00 DukeofAlexandria635.50 |
06-21-2023, 05:56 PM | #4 |
Rep 140
evolve should be dropping their custom valved bilstein b6's any day now for the E9x...
i'd image much like these f8x offerings... https://www.evolveautomotive.com/pro...db27b46c&_ss=c thought i'd read the damptronic B6s effectively raised the ride height 1/2" or so... |
06-21-2023, 07:00 PM | #5 | |
Rep 90
Following for updates. |
06-22-2023, 05:53 AM | #6 |
Όλα ρόδες
823
Rep 606
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Not even sure that the b16 edc kit is available. Paid for it in January through a German online retailer. Once a month i would ask for an update on my order and the vendor would reply that Bilstein would give them dispatch date the following month. After 6 months i got tired of waiting and just cancelled my order. At least the vendor refunded me the following day. Any suggestions, other than bilstein part no Bilstein 49-237108?
06-22-2023, 12:51 PM | #7 | |||
Rep 332
My understanding of Bilstein (and I could be wrong) is the B4 are OE replacements, B6 is OE+ so more sporty, and B8 (if avail.) is B6 but for lowered cars. Quote:
Going back to the EDC question, do you guys think EDC in sport mode actually improves handling? Or is it a gimmick...
-Thumbie
06-22-2023, 04:21 PM | #8 | |
Rep 26
Thumbie132.00 |
06-22-2023, 05:50 PM | #9 | |
Rep 4,341
2. 10-15% less comfortable than Ohlins R/T, 30-40% more comfortable than stock EDC. A lot better body control than stock EDC. 3. Big difference switching modes on TracTive vs Ohlins R/T. The active DDA valve makes a huge difference to roll and pitch control. |
06-22-2023, 09:09 PM | #10 | |
Rep 464
I think EDC settings are mostly adjusting rebound. May be some cross talk with the compression but mostly rebound. Preload is how much the spring perch and top hat compresses the spring while it's not under load with the car sitting on it. You can't adjust that with OEM shocks, but you can with many coilovers. Wheel rate is like spring rate but it's effective at the wheel instead of at the spring. Since the suspension arm acts like a lever, and different cars have different attachment points, not all spring rates are comparable between cars (or even the front/rear of the same car), but wheel rate would be. See below for the math and explanation of what motion ratio is also. Last edited by Tommysalami; 06-26-2023 at 02:33 PM.. |
06-23-2023, 09:16 AM | #11 | |
Rep 581
They'll be here soon though, and we honestly think they're part of the perfect setup for a road use car. |
06-23-2023, 11:56 AM | #12 | |
Rep 332
I know there is a lot more factors involved in wheel rate, I am just generalizing here.
-Thumbie
06-23-2023, 08:02 PM | #13 |
Rep 4,341
EDC is actually an active system that constantly changes damping based on driving conditions like steering angle (amongst others). Helmsman has made some videos showing how EDC varies damper amps based steering motion (the vids are in my TracTive thread).
The problem is that the factory EDC dampers are too slow to react to those changes. The TracTive damper DDA valve on the other hand works very nicely with EDC and actually changes roll and pitch control depending the EDC setting and what the car is doing. |
06-26-2023, 12:30 PM | #14 | |
Rep 332
Man... I gotta say, the more you talk about the Tractive the more I am considering buying
-Thumbie
07-04-2023, 12:35 PM | #15 | |
Rep 210
Drives: 2018 X5
