03-17-2019, 04:48 PM | #1 |
Rep 4,341
BBS RGR 762 18x9 ET 45 with 15mm spacer M3 fitment
Fellow BIMMERPOSTers. I know it's not listed as an option for the E90 M3 but has anyone here ever put BBS RGR 762 which is 18x9 ET 45 in the front of an E9X M3? The competition package wheels I have are 19x9 ET 31 and I have run APEX EC7 in 18x9 ET 31 with no issues. I am really interested in a set of 18" BBS RGRs but want to keep the 9" wide front. The only thing they make is an 18x9 ET45. With a 15mm spacer, that would give me 18x9 ET 30 which would be perfect. I'm just concerned about break clearance.
Anyone ever fit these on an M3? Thank you. |
03-19-2019, 09:36 AM | #2 |
Rep 6,734
That would technically work but why limit yourself to a 9"? I would have to double check with BBS but I don't think that version is produced any longer. They only have 8.5 and 10 at this point. Did you find it used? The 18 x 10 et25 version is what I would choose given the options still available.
'23 X7
03-19-2019, 09:58 AM | #3 |
Rep 3,988
I'd rather run 18x10 et25 without a spacer than run 18x9 with a spacer.
Personal preference i guess.
03-19-2019, 10:12 AM | #4 | |
Rep 4,341
If they offered an RGR in 18x9.5 ET 27 and someone made a tire with the correct diameter that fit the front, I would consider that. they do make an 18x9.5 front that would work albeit with the smaller diameter and there is no 10.5" wide option for the rear, only 10" wide in 18" sizes. They list an RG762 18x9 ET45 in the BBS Japan site, so thought it might be available still. I know looks are subjective but to me, the cars look ugly with the front wheels bulging out. The only thing BBS makes now that is close to what I want is the RIA but not really sure about the look on the 1M. The spokes are too rounded. The FI is a little flatter and looks better, so still looking. I wish they made an LM in 18" for us, but I love the classic style of the RGR. That's why I am limiting myself to close to stock offsets. What sets the 1M apart from M2s and new M3s is a bit more feedback and steering feel, I don't want to mess that up with 10-11 mm off the correct offset. I care about looks but also function. Thanks for all your input and help. I hope that helps explain it. |
03-19-2019, 10:15 AM | #5 | |
Rep 4,341
Thanks |
03-19-2019, 10:21 AM | #6 |
Rep 4,341
Here are 19" RGRs I got for my car...over $4500K spent, still have brand new BBS spacers, center caps left over, just threw money away. I had to go with 8.5" wide front instead of stock 9" wide and gap didn't look good. Had to sput 10mm spacer to look decent but then steering feel got weird. Didn't like it.
18x9 ET45 with 15mm spacer would give me ET30, pretty close to stock offset. By the way, I know this is an M3 forum but these are the same wheels and offsets and there is more activity on the M3 side. just not that many 1Ms around in case anyone is wondering why I posted here. |
Krypptic43.50 |
03-19-2019, 11:56 AM | #7 |
Rep 6,734
OK, I'm tracking with you better now. You must be on stock suspension. The reality is that the 10" front and/or the 9.5 et22 front wheels are designed for cars with camber. Both of those wheel specs are actually conservative and would not stick out past the fenders on a car with a more aggressive alignment. My experience is that BMW's really like at least -2 camber in the front. Even for street use. If you don't have camber plates I would consider them. At the very least pull the alignment pins on the top mounts and maximize your available camber with the stock setup (about -1.5). For example, see my pic below. My front wheel fitment actually looks conservative despite the fact that my wheels are 10 et15. This of course is due to the fact that I am running -3.5 camber.
Untitled by slicerM, on Flickr Your comment about losing steering feel is fair. I would say that the wider the tire is in front the less lively the steering will feel. However another factor is the width of the wheel relative to the tire. Assuming a fixed front tire size - a wider wheel will provide more side-wall support for the tire and improve responsiveness. A narrower wheel will allow the tire to roll over more when under load.
'23 X7
nachob2314.00 |
03-19-2019, 01:31 PM | #8 |
Rep 1,881
steering feel is a strange factor. I have 19x10 et25 with 275/30/19 on the front, and it feels lighter than when i had 19x9 et31 with 15mm spacer and 245/35/19 tire.
Also, my front wheels do not stick out, they fit perfect.
03-19-2019, 02:16 PM | #9 | |
Rep 4,341
I guess the bottom line is I would rather take the family to Hawaii for a week then keep buying wheels the sell them at half price because something wasn't right. I have already sold two brand new (basically) sets of wheels in the last year. Trying to make a better decision then outfitting SoCal with half price brand new wheels. . Another issue is that I have found that 18s handle better on our terrible SoCal roads. Less rear end skip etc. But everyone is into 19s and 20s for show. Yes they look better but I already have a beautiful set of ZcP 19s. The RGR and RIA are the only thing made by BBS in 18". I did also own a set of Apex ec7 in 18x9 et 31 and 18x10 et 25. They were outstanding and that's when I realized how good 18s are for the street. I bought them to autocross and put them on to try them out and loved the way the car handled. Turn in was slightly softer but the car handled better on the street. The 1M is very firm and the extra sidewall helps plant it a bit better on less than perfect roads. So that's why I want 18s. I know it's not popular here. Now if someone had a great deal on titanium fI bbs or Diamond Black/ Diamond Black 19" BBS LMs I might sacrifice some GO for SHOW. Thank you |
03-19-2019, 02:27 PM | #10 |
Rep 6,734
Why not get the BBS RIA? 18 x 9.5 et27 is available (which I believe you said would be appealing), plus 10.5 et25 is available for the rear. I think you are over-analyzing if you think the spoke design looks markedly different between RIA and FI. There are slight differences but it's negligible. This is coming from someone who has seen everything from BBS. I have been able to have the various options side by side. To me the RIA is the best bang for the buck.
'23 X7
03-19-2019, 02:42 PM | #11 | |
Rep 4,341
But yes. RIA is a contender still. |
03-19-2019, 05:39 PM | #12 | |
Rep 6,734
RIA price is right in there with the other quality forged wheel options. A bargain compared to the $8k FI. Where in CA do you live? We have a set in stock at MRF Engineering in Lake Forest, CA. I also have a set here in Santa Barbara. Let me know if you wish to schedule a time to view them.
'23 X7
