  TireRack
      09-27-2013, 11:48 AM   #1
sansri
Drives: 2018 G01 X3 M40i
Mixing tires
Looks like I need to replace the fronts on my M3 - the car has Continental Super Sport 3 and the rears have a ton of tread ~8/32. Should I stick with the Continentals or change to Michelin Pilot Super Sports up front?
If I had to replace all 4 then I would go with the Michelins...
      09-27-2013, 12:00 PM   #2
Z K
Z K's Avatar
Drives: E90 M3, B8.5 A4
For normal street driving it should be fine.
In terms of performance, it will probably handle a little weird when driving at the limit since you will have more grip up front and less in back... go drifting?
Auto Detailing Enthusiast!
      09-27-2013, 03:15 PM   #3
slicer
slicer's Avatar
Drives: '13 E92 M3
You are in a predicament there. I would not want to keep the Continentals and I would never mix tires. If it were me, I would sell the Continentals and snag a set of 4 Michelin PSS. Mixing tires is never a good idea because they will perform differently in the same conditions (unpredictable handling). I guess if you put around like a grandma then it won't matter but if that's the case why drive an M3? If I saw a used car with mixed tires I would assume that the owner has cut corners elsewhere in maintaining the car.
'13 AW E92 M3 - Ohlins TTX, SPL Susp Arms, AP Racing BBK (Essex), Cobra Seats w/BK Mount, Akrapovic GT4, CSF Cooling, VPhreaks Bat, OE M3 GTS - Lip/RSD/Cage, M235ir Wing, Varis Diffuser, Karbonius Airbox, BBS E88
'17 MR F31 M-Sport - BBS LM, H&R Springs
'Instagram - @slicer_m
      09-30-2013, 09:26 AM   #4
sansri
Given how much tread is left on the rear tires, I may just stay with the continentals for now and change to the PSS when the rears get worn out.
      09-30-2013, 09:33 AM   #5
chris s
chris s's Avatar
772
Drives: 2016 SMB F80 M3
replace your fronts, then swap to PSS when they're all worn. I wouldn't mix brands, hell, i wouldn't even mix within a brand.
2016 Individual F80 M3 - San Marino Blue|Full Amaro | Built by IMG Motorsport and Prime Performance | Mode Carbon | ESS | Akrapovic EVO | KW HAS | M Performance...
2012 MR e92 M3 DCT, fully loaded... GONE but not forgotten!
2008 e92 M3 Coupe 6MT | AW/BLK Extended...SOLD!
Search this Thread:
Advanced Search
