04-13-2018, 09:40 PM | #1 |
Rep 739
Ebay's "Team-2-Fast" Resonated Xpipe?
Has anyone purchased the Ebay Seller "Team-2-Fast" Ebay Xpipe? It's from Germany, shipped from Germany as well.
Search for "Rennauspuff X-Pipe" on ebay. I am wondering how fitment is with this pipe. Looks to be a Macht Schnell Copy? |
05-19-2020, 12:24 AM | #3 |
Rep 34
Let me know if you actually bought it!
05-19-2020, 12:50 AM | #5 |
Rep 2,747
I've had it, took it off and sold it after a couple hundred miles.. fit wasn't great sound wasn't good paired with a Megan.. had to trim heat shield to fit o2's and it didn't include ANY hardware so I had to source 2.5" 2 bolt gaskets too for the section 1 to x pipe and the bell connection to muffler wasn't a great fit.. could never get them not to leak.. Finish was good enough.. I wouldn't purchase again or recommend it..
9ers
dylansun5.50 |
05-19-2020, 04:32 AM | #6 | |
Rep 41
Lol, guess I am too late. Just bought the xpipe from them to pair up with my FI valved exhaust. It will arrive in a week or so, let's see how they fit.
05-19-2020, 05:37 AM | #8 |
Rep 259
I bought that xpipe pipe and it had to be modified. It didn't fit well! We had to cut the X and re-weld, in addition to adding a little more length since there was no way that it would fit well with the silencer.
I finally sold it and bought a whole full akra evo exhaust system
Instagram: @m_rochen
Alpinemss Tuned | Tecnocraft E9X ///M3 Envy™ Intake System | MS Pulleys | Akrapovic Evolution Exhaust | Ohlins Road&track| BBK Brembo 6p Front & Brembo 4p Rear| H&R Stabilisator| Solid subframe bushings| full spherical bushings| Recaro pole position |
05-19-2020, 05:38 PM | #9 | |
Rep 41
That's sad. What muffler did you pair it up with?
05-20-2020, 05:24 AM | #10 |
Rep 259
I paired it with the oem muffler:
As you can see in the red circles material had to be added to gain length and in the green circle we had to cut and re-weld it to fit well with the silent oem
dylansun5.50 |
09-06-2022, 07:14 AM | #12 |
Rep 42
Sorry for old thread bump. Bought from this seller resonated x-pipe but got catted version. Overall look not bad but fitment is bad. Rear end has totally wrong joint shape, must be spherical but has some mm uncut material. I did cut (grind) which left spherical diameter 4 mm smaller, sealed with tape.
Middle supporting section also wrong, did stopgap solution so lower crossmember uses 3 fixing points insted 4. Rear O2 positions also totally off, rear sensors measure ambient air now (old tune has sensors coded out and new tune has some own magic trick). Sound terrible with different mufflers, but atm with supersprint race acceptable. Can't suggest to buy this x-pipe. I'll probably make from this pipe H-pipe and delete rear x but before i test same solution on stock pipe. https://www.auto24.ee/products/produ...226815&view=10 |
