09-24-2010, 12:40 PM | #1 |
Rep 701
Non standard tire sizes and MDM/DSC.
OK, I will start with a recent experience on my Cayman. I lowered it, and installed new 10mm wider tires in the rear - 275 versus stock 265. I also bought, but did not yet install 245s for the front (again 10mm wider than stock 235.)
At the track I drive - Pacific Raceways in Auburn, WA, turn 1 is taken ON throttle at anywhere between 120 and 170 MPH (mostly dependent on size of your balls, and power of the car.) I take it anywhere from 120 to 130. Mor or less at the apex, there is a little bump, and you DEFINITELY want to have the car planted with throttle - no lifting or braking - or you are F...ed, someone else can find that You Tube video. With the above described tire setup my traction control kicks in at the bump and cuts throttle, possibly brakes the car. In other words my car is truly trying to kill me. I have ONLY experienced that with the current tire setup. Of course, I turn stability off as I like to keep the shiny side shiny. But that begs a M3 related question. Seems that everyone here drastically changes the wheels size ratios when they track their M3. Square setup is WAY off from stock and traction control computers must be going CRAZY. Do people with square setups just automatically disable traction / stability control? Or, not so on the M3?
I apologize for spelling mistakes up front, they are a result of multitasking.
09-24-2010, 01:21 PM | #2 |
Rep 7,887
Why do you run on the track with the traction control on?I have tried it with the MDM on track and it is way too intrusive even in the 100mph + corners.
09-24-2010, 05:41 PM | #3 |
Rep 701
Ohh, I am getting ZCP, which claims to have stability tuned for track / aggressive use.
09-29-2010, 09:06 AM | #4 |
Rep 751
DSC and TPMS with square setup
If I decide to do any regular track stuff with this car, I'll probably use either 265 or 275 tires all around, using a set of appropriate wheels. I know this is a common practice so just a couple of questions:
If I do not use pressure monitors, will any warnings other than the small red icon appear? I just don't want to deal with an endlessly recurring message appearing (I do not have tech package or i-drive). Second, since the OE wheel/tire setup has about 0.5" of OD stagger, does the use of identical tires create any issues? I will have DSC turned off, but in some cars, the change in f/r rpm bias will still cause problems with traction control and/or tire pressure warnings. |
09-29-2010, 09:15 AM | #5 | |
Rep 7,887
09-29-2010, 08:04 PM | #7 |
Rep 701
Mod please combine threads. (I just asked the same question couple days ago.)
http://www.m3post.com/forums/showthread.php?t=435596
09-29-2010, 08:05 PM | #8 |
Rep 701
Does the yellow TPMS warning go away after some time?
09-29-2010, 08:30 PM | #9 | |
Rep 751
09-29-2010, 08:32 PM | #10 |
Rep 751
09-29-2010, 08:53 PM | #11 |
Rep 701
09-30-2010, 12:09 PM | #13 |
Rep 4,048
Well if this is for a track specific set of wheels, I wouldn't bother with TPMS, just let the error go off as you'll save just a tad bit of weight with them, and you'll obviously spend less money with it.
BUT if you are running these on the streets occasionally, then sure, I would spend the extra cash to get TPMS in them as well. So with that in mind, lets move to track set up wheels. For an inexpensive set, with some super sticky tires, we can certainly set you up with those. I'm thinking a 18x9.5" ET22 set up all around, and running a 265 size tire all around to make it work out perfect. If anybody is curious on that set, just PM me and I can give you details. |
12-15-2010, 06:57 AM | #14 |
Rep 2,278
I have a square setup and take turn 1 at Pacific Raceways at approx 140 mph and there are no issues with traction control.
2015 f80 M3, 2016 GT3
12-15-2010, 10:57 AM | #15 | |||
Rep 4,445
I run a square setup with 275 all round easy to swap front to back. TPMS isn't needed, the warning stays but no issue.
12-15-2010, 03:42 PM | #16 | |
Rep 1,508
I bet you'll be fine.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates Previous: 2009 E90 M3 |
12-15-2010, 07:08 PM | #17 |
Moderator
683
Rep 4,737
From personal experience M3's stability/traction control is pretty flexible in terms of tire sizes... at least it does not completely disable the car (although performance might be affected). I have 265/35/18 and 295/30/18 which is pretty off vs OE but it seems to work with the controls. However I cannot say the system is as effective as if you were to use the standard sizes.
If you are in a more advanced group I would recommend turning it off... depending on DSC limits your ability to grow as a driver. |
02-28-2011, 09:21 AM | #18 | |
Rep 303
Seat-of-the-pants I sense that the DSC/ABS system needs some mileage to adjust the threshold for intervention when I replace the tires with the winters. It seems like when you first switch to the winter size setup, the DSC/traction control does not intervene as smoothly (allowing for much higher side-to-side slip) as it does after being driven for a while. I wonder if the DSC has two (or maybe three) program options - for 18", 19" and 18" square winter. None of the BMW materials I have read address the issue, though. For sure, ABS and DSC systems are much more sophisticated/sensitive now - they can adapt to wear in tire tread much more so than in the past.
03-01-2011, 07:06 PM | #19 |
Rep 5,483
+1 on the permissive DSC with respect to tire diameter on the M3. When my 275/40-18 rears were new and the (stock) fronts were at about 7/32", the DSC seemed a little more sensitive over bumps, now that the fronts and rears are both at about the same tread depth it seems to have settled down a little. The 1" diameter split front to rear might be a little too much for it to handle, now it's a little better as the new rears have of course worn faster than the fronts
It's probably looking at delta between wheel speeds so the DSC may be less intrusive the closer the tire diameters get. I wonder if the traction control on a car with a square setup is, in effect, running in a state similar to constant wheelspin, since the rear tires aren't supposed to turn at the same rate as the fronts with OE tires. This stuff is complicated I'm really impressed with every new generation of these systems I try, but I'm glad the M3 has the push-button off switch right next to the shifter, none of that holding a button down for 5 seconds "ARE YOU SURE YOU WANT TO TURN IT OFF YOU COULD DIE!!!" nonsense like my 335 has.
