07-12-2014, 08:33 AM | #1 |
Rep 532
Shift Lights - 2009 M3 - Intermittent
Experiencing what seems to be "random" shift light in a DCT car. Mine seem to be operating sometimes.. not all the time (which is what i want).
I have both I-drive M key settings set to "shift lights on"... and the "shift lights on" setting is set in M Drive. (layman's bad explanation) But -- yesterday -- driving home on an onramp.. AGAIN no shift lights. I just about hit redline, so I'm sure. Then. 5 mins later. Car had not been turned off. Same key (obviously). 1st gear. Shift lights came on. As far as I know, I am not crazy, and my eyesight is good I've noticed this a few times recently. Anyone else seen this? NOT the end of the world because in reality I'm just driving around and not on a track or anything where it's actually information I need to drive the car well... but still... I think they are cool, and I like to see them when they should be on. |
07-12-2014, 09:22 AM | #3 | |
General
68556
Rep 26,163
But...don't forget it's a ///M(MDM) setting and only will work when MDM button (on your steering wheel) is activated ! So when MDM button is not activated,shift lights will not work ! Personal i'm thinking that's the cause of your problem . Hope this will help......
07-12-2014, 12:36 PM | #4 |
Rep 248
Drives: 2013 E92 MW M3
Shift lights should come on if you have turned on setting for shift lights to come on in the I-drive even when not in M mode. Mine comes on even when not in M mode. It sounds like something is not working properly.
07-12-2014, 12:44 PM | #5 |
Rep 663
MDM has nothing to do with the shift lights - They can be set to work with or without MDM mode. They only light up under heavy throttle. If you're heavy on the gas, they light up but if you slowly climb to redline, it won't
You can set the shift lights through options. Search the forum |
07-13-2014, 11:38 AM | #6 |
Rep 7,210
Agree, checked this today and same here; ones set in M-key it doesn't matter whether M-button is engaged or not but should show shift light.
07-13-2014, 01:43 PM | #7 |
Rep 532
I think this may be the answer -- "MDM has nothing to do with the shift lights - They can be set to work with or without MDM mode. They only light up under heavy throttle. If you're heavy on the gas, they light up but if you slowly climb to redline, it won't "
Earlier yesterday when i was testing it out... I was just downshifting to get the revs higher, ... maybe that's it. I drove around last night and in s (manual Dct mode) i was getting shift lights. Interesting, i guess I just assumed that they'd light up 100% of the time. |
07-13-2014, 03:19 PM | #8 |
Rep 7,210
Hmm, I wonder. I'd say the light is relevant to show yr coming closer redline regardless how fast u get there?
I'll check tomorrow! Cheers Ps. But yes, guess it only works in manual - never checked auto as not relevant in that mode. |
07-13-2014, 10:34 PM | #9 |
Rep 663
The shift lights are meant to draw attention to the revs when your eyes are presumably on the road under heavy throttle. The reason they don't light up when you slowly climb is because you should be able to either hear or visually see the revs coming close to redline.
07-14-2014, 01:12 AM | #11 |
Rep 458
has nothing to do with the M setting. it's how much throttle you give the car. just like you can't engage launch control just anywhere, the shift lights will not light up unless you drive with a real heavy foot.
Personally, I find them only useful in the most ideal situations, i.e. road conditions, closed track, etc... because the car wants to be driven very hard when it starts showing the shift lights.
'07 E92 | Space Grey | Sport | Premium | JB3 | aFe DCI Stage 2
07-15-2014, 02:35 PM | #13 | |
Rep 7,210
cheers |
