09-14-2018, 05:48 PM | #1 |
Rep 136
Drives: 2013 BMW M3 Frozen Red Edition
Do I Have a Bad M3 or Am I Just Unlucky?
Hey everyone,
So I've had my E92 for only 2 and a half months and I've had some serious issues already. I've had to replace both the throttle actuators, the thermostat, the alternator, an O2 sensor, and now my drivetrain. Thankfully my warranty is covering everything but if I skipped out on that, I'd be down a little over $7k. Is my car just a poor functioning M3 or am I just getting unlucky? Is this what life with an E9X M3 is like? |
09-14-2018, 06:18 PM | #2 |
FROZEN SILVER
112
Rep 466
Hard to tell because like any car it depends on its history, maintenance, etc...
My e92 is over six years old 29k, bought it new. Zero issues of any kind.
CURRENT RIDES - 16 991 GTS 7MT/ 12 FROZEN SILVER E92 M3 / 03 GPW S2K AP1
PREVIOUS M CARS - 02 E39 M5 / 06 E60 M5 / F10 M5 6MT 14 991 C2S |
RosieTheRedM3266.00 MachinesWithSouls4835.50 |
09-14-2018, 06:32 PM | #4 |
Rep 4,014
41k miles in two years on two M3's and have only had one repair, a breather valve. Its luck of the draw. Lucky you have a warranty for sure. It would have been wasted on me.
RosieTheRedM3266.00 94jedi829.00 |
09-14-2018, 06:48 PM | #5 | |
Rep 394
I think the TAs, thermostat, and alternator are going to be considered normal maintenance items (debatable in general on the TAs, but unfortunately on this car it's a given they'll go at some point). O2 and drivetrain not so much. As others have pointed out, there's really not much else major that could go wrong at this point except *cough* rodbearings *cough*. Probably have to do sparks / coils at some point also, but also maintanance items. |
RosieTheRedM3266.00 |
09-14-2018, 06:56 PM | #6 |
Rep 4,163
If it's any consolation, I went thru the same experience 2 years ago. Got my M3 used at 5 yrs old and 70k kms. With BMWs, you gotta expect things to start breaking at 5 yrs.
I spent the first year and half dumping money into the car. Alternator left me stranded with a dead batt. Brake vacuum sensor put me into limp mode. Swapped out nearly the entire braking system over the course of 2 years to diagnose a spongy brake pedal issue that turned out to be a leaking ABS pump. The first year of ownership I literally considered burning the car, I hated it that much. To me, it was one of the most unreliable cars I had ever owned, and I've mainly driven Italian and French marques. And the dreaded M Tax didn't help. Once I got over the initial period of parts replacements, it began to stabilize. Car has been rock solid for the last 18 months. I have done some items preemptively, such as TA, and cooling system components just cos the car was getting up there in mileage. So hang in there. It will stabilize. Just don't expect to drive an M like a normal car. It will require preemptive maintenance of wear and tear parts. Using a part til failure may cause even more headaches down the line. |
09-14-2018, 06:58 PM | #7 |
Rep 136
09-14-2018, 06:58 PM | #8 |
Rep 136
09-14-2018, 07:05 PM | #9 | |
Rep 136
09-14-2018, 07:46 PM | #10 |
Rep 1,239
08 with 100k. Only replaced idler pulley and tstat .
RosieTheRedM3266.00 NoHedge67.50 |
09-14-2018, 07:47 PM | #11 | |
Rep 362
But seriously, your car is a decade old and parts will break and will need to be replaced. I just spent a month doing a complete suspension refresh on my 2003 E39 (all original parts). The car drives like new again.
09-14-2018, 07:49 PM | #12 |
Rep 3,274
Not only is the car ten years old but it was the first of it's generation. Yeah I'm one of those people who would never ever buy the first year of a new model.
Also you should get your Rod Bearings replaced ASAP, you have the bad bad ones
RosieTheRedM3266.00 mrdoja33.00 |
09-14-2018, 07:50 PM | #13 |
Rep 136
09-14-2018, 07:51 PM | #14 | ||
Rep 136
09-14-2018, 07:52 PM | #15 |
Rep 136
09-14-2018, 07:57 PM | #16 |
Rep 765
My recommendation learn to do the basics if you haven't already then get someone that knows these cars to do the real work. I have had dealers leave things untightened, indie shop overfill oil and say "oops sorry".
I'd also build a maintenance schedule of your own and just get into practice of doing things preemptively. For example spark plugs you can do quite easily. As for your actual questions seems you have some bad luck but as long as there isn't anything fundamentally wrong with the car, my call is that getting through the list will get you into a good status and a vehicle that rewards you with the experience. I love this car every time I step into it. Stuff like this is why I am for the warranties. Sort of sucks to pay the cost of rod bearings and not use it but so far all cars I have owned the warranty has proven to pay back its worth. |
09-14-2018, 08:00 PM | #17 | |
Rep 136
09-14-2018, 08:17 PM | #18 |
Rep 137
I would say you are lucky all this stuff is going out while you're under warranty. Hopefully when it's out, nothing else will break for a while.
09-14-2018, 08:25 PM | #19 |
Rep 43
09-14-2018, 08:32 PM | #20 |
Rep 136
It was bent or cracking or something. Not entirely sure but it made a clunking sound everytime I put it in gear
09-14-2018, 08:33 PM | #21 |
Rep 136
09-14-2018, 08:45 PM | #22 |
Rep 1,095
how many miles is your car? that's a lot of work needed in such a short time. Did you do ppi on the car?
2011 MR e90ZCP, 6-mt
2011.75 e90 M3 ZCP, DCT, ZP2, ZCV, JB w/ 2Toned FoxRed/Black Interior - SOLD |
