11-16-2018, 01:22 PM | #1 |
Rep 209
Anybody have experience with curb ramps?
I have a pretty steep driveway and a lowered f80, and scrape the front bumper every time I come in, due to the curb being raised. Is anyone experienced with any of the myriad of solutions out there and have reccomendations? I'm trying to do this before I cave and get KW coilovers with the lift system, cause I hate coils
11-16-2018, 01:26 PM | #2 |
Rep 569
There's a bunch of products similar to this: https://curbramp.us/
Alternatively, you could try reversing into your driveway every time haha |
11-16-2018, 01:27 PM | #3 | |
Rep 209
that's why I was asking if anyone had good experiences with any of them, cause there is an overwhelming amount |
11-16-2018, 02:28 PM | #8 |
Rep 209
11-16-2018, 02:33 PM | #9 |
Rep 994
11-16-2018, 02:34 PM | #10 |
Rep 209
KWs dont retain, and KW is the only company that has the hydraulic lift option, which would be my whole reason for getting it. The F80s I've ridden in with coils ride like absolute horseshit, to the point I dont know I could handle dailying with them. I think an air suspension would suit my needs, but they're retarded expensive and fuck handling
11-16-2018, 02:35 PM | #11 |
Rep 209
manual dampers are worthless. that means when I turn into a road and realize its bumpy as shit I have to get out of the car to adjust them
11-16-2018, 02:38 PM | #12 | |
Rep 994
11-16-2018, 02:39 PM | #13 | ||
Rep 209
and im not sure if I can justify to my woman spending like 3500 or so dollars on an air suspension just to get into the driveway, when I could have just plopped something on the curb |
11-16-2018, 02:47 PM | #14 | |
Rep 994
11-16-2018, 02:48 PM | #15 |
Rep 1,425
I'm in a F31 (Wagon), and my car appears lower than your F80. I have a decent curb at the beginning of my driveway. If approaching directly, I scrape the front every time. I was about to order a curb ramp, or have a professional concrete/paver do some custom work. However, I modified my entry and exit, and have minimal-to-no scrape. It may not work for your vehicle, but there are some Youtube videos with demonstrations. Basically, I approach parallel to the road, about 3 feet from the driveway. I then turn the wheel to match the driveway and very slowly let it crawl up. Same thing in reverse when exiting.
Now, I do have KW with EDC controls. I typically stiffen them to the Sport setting before approaching or exiting the driveway. KW makes coilovers for your F80 that are EDC controlled. In fact, they are literally plug-in-play. This is what I have on my F31. They are called DDC Plug-and-Play. This should be the part for your F80, but please verify: https://www.kwsuspensions.com/produc...-39020039.html
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
11-16-2018, 02:55 PM | #16 | |
Rep 209
11-16-2018, 02:56 PM | #17 | ||
Rep 209
11-18-2018, 01:32 AM | #18 |
2JZ-GTE
3032
Rep 3,992
Friend built custom solution using parts found at the local Home Depot
11-18-2018, 05:00 AM | #19 |
Rep 1,815
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
11-20-2018, 01:25 PM | #20 |
Rep 74
I use Bridjit (https://www.bridjit.com/). It has worked pretty well, although sometimes it slips down a bit. Even with it sliding, it still prevents my Corvette from scraping my driveway.
