05-27-2021, 06:42 PM | #1 |
Rep 1,178
AC warm, evap already replaced in 2017
Original 2013 year model owner, AC was weak from the factory, mediocre but worked. Complained about it for 3 years (under warranty) with the dealer, until in my last year of warranty it got bad enough that they had to do something and replaced the evap and recharged the system.
After that, it slowly got weaker over the years again and now 2021, same shit, warm again. 2013-2017 is 4 years 2017-2021 is 4 years too ! This tells me they never found the original leak and the same leak is responsible. Any thoughts ? I am planning to bring my original invoices and ask them to warranty the work that has failed again. (i have no extended insurance plan) |
05-27-2021, 07:10 PM | #2 |
Rep 4,163
Does it get progressively warmer over the 4 yrs or is it sometimes hot, sometimes cold. If it is leaking, and takes 4 years to lose gas pressure, is it really a big issue? Just top up your ac gas every 2-3 years.
05-27-2021, 07:35 PM | #3 | |
Rep 1,178
How much should an AC recharge cost at the dealer ? I'm thinking first presenting all the evidenced past A/C related invoices (They recharged AC three times under warranty if including the evap job) and asking them to warranty that work since it obviously failed again. If i get nowhere with them and they want to charge to find leak, I'll ask for just a recharge. |
05-28-2021, 05:27 AM | #4 |
Rep 66
there is a normal allowable leakage in an ac system, if ac is not used for extended period of time will allow small leakage over time past o rings. thats not saying something isnt leaking but like other people say maybe you just need to recharge every couple years, i have done that on my own vehicles
05-28-2021, 05:48 AM | #5 | |
Rep 1,178
My M3 A/C already gets in the "not cooling properly" within 3 years and "almost like no AC" by the 4th year intervals. These numbers aren't acceptable. It's my experience bmw is notorious for not recognizing and owning their factory originating defects. But can you give a figure on a recharge cost from the dealer ? |
05-28-2021, 07:02 AM | #6 |
Rep 1,287
Dealers will charge 2x what an independent shop will. I refilled my ac with cans from autozone 4.5years ago and it still blows cold. So yours shouldn’t be having problems.
I’d go to a good indy shop, not a dealer. They’ll use a dye in the test and find the leak. |
05-28-2021, 07:11 AM | #7 | |
Rep 1,178
And that the m3 AC refrigerant required pressure is much tighter than older AC systems +/- 0.5 lbs and if you put too much only by a bit, the compressor will fail with time. Last edited by Rajmun340; 05-28-2021 at 07:18 AM.. |
MilehighM3915.00 |
05-28-2021, 07:27 AM | #8 | |
Rep 1,287
Rajmun340413.00 |
05-28-2021, 08:00 AM | #9 |
Rep 3,987
Sadly alot of jobs were done very sloppy by dealer techs. I forgot the hours, but I remember the job not paying well under warranty and it was a time consuming job.
Techs would rush the job and generally not do it properly so it would leak again. Sadly techs being paid a flat rate, give them no incentive to do a good job, esp if the come back chance is years down the road. Techs want to make money, they want to finish 8hr jobs in 4hrs. If a job pays 8hrs and takes 8hrs, they will generally whine and moan all day and I've seen shitty work because of it. |
05-28-2021, 08:43 AM | #10 | |
Rep 1,178
Almost every other repair would return the car with some side damages that most people won't notice until later. They often fail to fix issues despite all the step by step bmw software diagnosis tools they are following. BMW is slow at learning the real issues their cars have and their automated decision software often direct techs in the wrong direction because they don't adapt the software over time to real problems encountered in the field. Then to block you from complaining further they write invoice saying the problem is fixed when sometimes it's not. You come back later and they claim they fixed it last time but didn't. All i can say is my experience with other brands was never as bad. Last edited by Rajmun340; 05-28-2021 at 09:04 AM.. |
05-28-2021, 09:22 AM | #11 |
Rep 258
A lot of the times it's not the manufacturer, but the dealer themselves that refuse to stand behind the product. Though yes, a lot of techs half ass their work due to flag rate, and wanting to make as much as possible. once a dealer touches something, the manufacturer hold THEM responsible. (and yes, some jobs don't pay "well" for the work that needs to be done, but you win elsewhere, i assure you. SO, sometimes, theyd rathe make their 1.4 on a quick recharge, then rip your dash out.
Do note: BMW has weak evap cores, there have been updates for some models. 4 years, isn't really bad for freon being a 'little' low. But, it doesn't hurt to have it checked out. Bad diags get back flagged, shit surveys takes money away at the end of the qtr, etc etc. Overall, dealers are so desperate to hire 'techs' that they just hire almost anyone, and pray they learn. Leading to shit dealer support. R134a, recovery, vacuum/leak check, and recharge should be anymore than ~$200 afer taxes and all. Probablyless at an indy. Also, ask if they have a freon sniffer, helps check evap cores, etc. |
05-28-2021, 09:44 AM | #12 | |
Rep 1,178
05-28-2021, 09:46 AM | #13 | |
Rep 1,287
You've got quite an attitude and high expectations for a guy asking for help. Stop being cheap and go pay an indy shop. Otherwise dont be a dick on the forums when ppl are brainstorming on your behalf. |
05-28-2021, 10:47 AM | #14 | |
Rep 1,178
Furthermore i did politely thank him first. Stop being a dick and interfering with normal thread process, if you cannot take normal argumentation then don't post on the forum. |
05-29-2021, 06:07 AM | #15 | |
Rep 66
MilehighM3915.00 |
05-30-2021, 03:05 PM | #16 | ||
Rep 34
There is for sure flaws in flat rate. But it really helps get customers cars out. Otherwise you'd have joe shmoe on the shitter wasting time instead of getting the work done. |
BP709230.00 white_4door22.50 |
05-31-2021, 08:44 AM | #17 | |
Rep 946
Short of that I would personally buy a can of DIY freon (with no additives, they do have these) and top it off myself. Done that dozens of times over the years with many different cars. Also I have never had an adverse issue when using the type that contains dye and o-ring treatment to help reduce a leak, and in some cases it has worked, YMMV. But using these will not cause your AC system to grenade itself, that is just urban myth. BMW AC systems are nothing special, and I have always found them to be a bit weak, and comparing them to your honda, well they are never going to be that good. Sad to say.
05-31-2021, 09:29 PM | #18 |
Rep 355
Every few years the A/C in my 2009 stops blowing cold air. At first, I added a can of refrigerant and it worked for the season. After a few years of adding it, I had my friend at a body shop evacuate and recharge the system and the machine did not detect any leaks or issues. That worked for a while and then it started to get warm again so I added more refrigerant. I used this one and had good luck. Each year when it starts to warm up in the Spring I test the A/C to see if I am going to have to add more. This year I did not add any and everything seems ok so far.
Adding it is a pretty easy DIY job, especially if you have done it before. The connector that you need to get to is buried so you have to remove a cover under the hood by the wipers but it only takes a few minutes. |
Rajmun340413.00 |
05-31-2021, 10:15 PM | #19 |
Rep 371
https://www.1addicts.com/forums/showthread.php?t=887759
Check that link, some e9x I was told may have had those same failing parts. I had this issue on my 135i, changed 2 times under warranty as it kept failing after a year. |
06-01-2021, 02:57 PM | #20 |
Rep 1,195
If for whatever reason you're not comfortable recharging it yourself for cheap then take it to a shop. Otherwise, BMW isn't going to listen to your theory of the worlds smallest leak that takes 4 years to manifest.
MilehighM3915.00 |
06-01-2021, 02:58 PM | #21 |
Rep 371
06-01-2021, 03:32 PM | #22 |
Rep 1,692
it's better to have a AC specialty shop do it, they have better methods of adding freon.
