12-02-2018, 01:28 PM | #1 |
Rep 747
Car wont start unless battery tender showing %80 charing and above
I am just looking for feedback. Battery test shows good for my 3 year old battery but wont start car unless I put it on battery tender and charge is above %80
I dont have any of the symptoms of showing battery is dying (no clock reset.. etc) I bought a brand new battery just to see if really the battery is the proper and I am having exact same issue of not starting unless battery is above %80 Any one had same problem? Is it really battery or IBS is going Bad? I also disconnected the IBS from battery but that didn’t help as well. |
12-02-2018, 02:06 PM | #2 | |
General
63331
Rep 24,664
Mvy540.50 |
12-02-2018, 03:09 PM | #3 |
Rep 126
I’m having a similar issue where I would put the car on a battery tender overnight and it would charge up to full. The next day I would take it out for a drive and come back to put it back on the battery tender and it shows as low. Ran codes and got 9D12 which has to do with the anti theft alarm battery system. Could this be a cause of parasitic battery drain? My battery is somewhat new being 3-4 months old.
12-03-2018, 04:07 AM | #4 | |
mTekMods
2142
Rep 2,902
12-03-2018, 11:34 AM | #5 | |
Rep 747
///M Power-Belgium63331.00 |
12-03-2018, 12:01 PM | #6 | |
General
63331
Rep 24,664
If I charge my battery with my CTEK charger . I can start my car at anytime even when it's pretty low at only 25% . My CTEK pictures => #26 https://www.m3post.com/forums/showth...1#post15488771
12-03-2018, 12:30 PM | #7 | |
Rep 747
12-03-2018, 01:30 PM | #8 |
General
63331
Rep 24,664
I have no idea .
12-03-2018, 04:55 PM | #9 | |
Rep 747
Something must be draining the battery and I cannot figure this out. If I fully charge battery with battery tender then remove the negative battery terminal and leave it overnight then test battery again. It stays 95% charge however if I keep the negative terminal on the battery overnight, it drops to %60. I cannot figure out what the problem is |
12-04-2018, 07:00 AM | #10 |
Rep 1,118
You need to do a load test on battery.
It very well could be the starter, that’s going. I just had a similar problem, battery tested OK, and the starter finally died. |
12-04-2018, 09:33 AM | #11 | |
General
63331
Rep 24,664
12-04-2018, 01:20 PM | #12 |
Rep 747
I am going to do a load test on battery today at nearby shop. But how can I determine if starter is giving up? Does the starter drain the battery overnight? I am only not able to start the car when battery is no longer holding the charge but I can start it every single time when battery is fully charged so this should rule out the starter
12-04-2018, 02:41 PM | #13 |
Rep 126
Did you run to check for any codes? I am having a similar issue and got a code for my anti theft alarm system battery being out which most likely is draining the main battery but have been trickle charging until I can troubleshoot the faulty batteries.
12-04-2018, 03:14 PM | #14 | |
Rep 1,118
Mine would start with a battery tender, then wouldn’t start the next day. There were no codes. Load test first. |
12-05-2018, 06:47 PM | #15 | |
Rep 3,735
Either your battery safety terminal (unlikely) or the starter has failed.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
12-05-2018, 08:53 PM | #16 |
Rep 747
12-07-2018, 12:17 PM | #17 | |
Rep 3,735
Have you checked your grounds?
12-07-2018, 01:11 PM | #18 |
Admiral
930
Rep 3,886
12-07-2018, 01:17 PM | #19 |
Rep 10,614
Check the ground by left side header collector. Mine was disintegrating. Give it a tug.
Quick test. Put jumper cables from block to chassis under hood, with both cables as grounds. Then start car. Should fire right up. |
12-07-2018, 05:59 PM | #20 | |
Rep 747
pbonsalb, are you talking about engine block? also chaises is painted so what part of chaisses are you talking about |
12-07-2018, 07:16 PM | #21 |
Rep 10,614
Engine block ground.
Obviously find bare metal or scratch some paint to ground. Go from the engine lift hook to a factory ground lug on the passenger inner fender for a test. |
12-08-2018, 07:03 AM | #22 | |
Rep 1,118
There’s a silver metal jumper piece on the right side of engine bay. Remember you’re using one cable only as a replacement for ground. |
