06-06-2019, 03:03 PM | #1 |
Rep 457
Camber plates as first handling upgrade?
Hey guys,
Just completed my first track day at streets of willow, and to me, the most glaring issue with the car isn't power or braking, I was struggling for front end grip at the limit. At sharp, moderate speed turns and sweeping high speed turns, the car tended to understeer. I'm on stock EDC suspension, which actually seems to make a huge difference on-track, less-so on street. Am I right in thinking that coilovers / struts / springs aren't going to make a huge difference and I should just make the jump to something like Ground Control camber plates, which are compatible with the EDC? Thanks |
06-06-2019, 03:27 PM | #4 |
Rep 21,727
What tires were you running? Coil overs and camber plates do make a huge difference if you go with a quality set.
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 06-06-2019 at 03:33 PM.. |
chocstraw495.50 |
06-06-2019, 04:59 PM | #5 |
Rep 457
MPSS from 2016, 245/265 on ZCP rims.
I did a 1:35.xx, I guess people said it was a good time for a first track day on a mostly stock car. I’d like to keep EDC, the more I use it, the more I notice how much it helps control body roll. Nice for daily driving too. Is EDC competent enough with good alignment and suspension components or will I notice a truly drastic change if I sacrifice daily drivability with coilovers? The whole front end of the car didn’t feel as stable as I’d like. |
06-06-2019, 05:46 PM | #6 | |
Rep 1,036
If you go with camber plates now and decide to upgrade in the future, you'll be doing the work twice and will need to make the camber plates work with your new suspension. I'd decide now and do it all at once if I were you.
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
chocstraw495.50 |
06-06-2019, 06:28 PM | #7 |
Rep 1,664
I had this dilemma, in the end I went straight to GC camber plates with Ohlins. My thinking was if your going to spend money on labour for camber plate install and alignment, may as well go to a full coil setup. First time on track with the Ohlins this weekend, i'll write a full review. Even in 50 street miles I can tell they are a significant upgrade with very little loss of civility.
chocstraw495.50 |
06-06-2019, 11:51 PM | #8 |
DSC Off!
304
Rep 718
If this is your first track event, do a few more events to see how hard the bug bites you. You learn a lot in the first few events. You can pull the pins to get more camber and adjust for a little toe out to help with turn in.. Also, tire pressure can significantly impact setup and turn-in.
If you're like me, you'll want a more track-focused setup than the Ohlins R&T.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
06-07-2019, 04:50 PM | #9 |
Rep 457
I think I'll pull the alignment pins today and get it aligned to my specifications. Slight toe out, as much negative camber as they can get.
What is an ideal hot, just off the track PSI for tires? I've been hearing 28-32 |
06-07-2019, 05:51 PM | #10 |
Rep 400
06-07-2019, 06:03 PM | #11 |
Rep 21,727
Yeah more like 36-38 PSI for street tires.
chocstraw495.50 |
06-07-2019, 08:49 PM | #12 |
Rep 457
Previous owner already pulled the pins!
Maybe Carmax gave it a very conservative alignment when they had it in, or maybe a driver mod is the most pressing upgrade! |
06-07-2019, 09:10 PM | #13 |
Rep 457
One pin pulled, other one still in.
Trying to piece together the story of a used car is always interesting. Edit: pins were pulled and giving the car positive camber, pushed in the opposite direction of what is desired Last edited by chocstraw; 06-07-2019 at 09:26 PM.. |
06-08-2019, 09:31 AM | #14 |
winner of many hpde trophies
47
Rep 120
why would someone pull the pins and then align it for positive camber? That's awful.
Even with the pins pulled you won't get enough negative camber to wear street tires evenly on track. You need camber plates to get even tire wear, otherwise you're just throwing still decent tires away because you corded the shoulders. Just buy them- they're quick and easy to install and you'll love the results. |
chocstraw495.50 SYT_Shadow11487.00 |
06-09-2019, 10:06 AM | #16 |
Rep 46
Mine is also stock EDC with pins removed , now 1,5negative camber.
Much better, no understeer at high speeds turns. Only short sharp turns the car understeers. Tire presusure with MPSS 35PSI I think you dont need camber plates with a nice coil over set like Ohlins R&T if you also daily drive your M3 |
chocstraw495.50 |
06-11-2019, 06:44 AM | #17 |
mTekMods
2142
Rep 2,902
Next step would be a wider front tire setup if not coil overs.
06-11-2019, 07:14 AM | #18 |
Rep 1,664
I can tell you after a full track weekend the Ohlins are a significant upgrade from stock. I found the stock suspension quite frustrating due to heavy roll on sweepers and the general lack of control on weight transfer. The stock suspension would also take time to really settle which delayed getting on the power and made the car feel lazy.
Car feels lighter on it's feet and more resolved. It deals with bumps in one suspension stroke (going over curbs for example) and the car feels generally more tied down. It controls weight transfer in a much more timely manner and whilst the car still feels quite heavy generally it masks the weight more effectively. I also moved from PS4S to RE-71r (do it immediately, they are amazing tires the grip is phenomenal) and despite the stiffer springs and sidewalls road manners are very good, they are perfect from the street dialled back to 10 clicks from stiff or so. I would caveat this that they are clearly not a full track suspension as they don't quite have the stiffness and immediacy some people might want in a dedicated setup. Even run 1 click from full stiff on the lower speed tighter corners there is some roll. For ultimate grip this may not be a bad thing however, it depends what you are looking for out of a setup. I can say they removed the frustration from the stock suspension and made the car way more enjoyable and confidence inspiring to drive fast, which ultimately is what its all about. For the money, performance and the fact there are little to no street comfort trade offs they work very well indeed. Bonus - I also added monoballs at the same time, they add a touch more precision and remove some of the 'gloopiness' the stock steering can have. A lot less shimmy under heavy braking, nice upgrade to add if your doing coilovers. |
06-11-2019, 07:19 AM | #19 | |
///M Powered for Life
11487
Rep 10,329
On a fresh EDC suspension with camber plates you can be quite fast. 'Fast' means different things to different people, but you can certainly be at pace in the fastest run group at PCA with EDC+camber plates. |
chocstraw495.50 |
06-11-2019, 07:20 AM | #20 | |
11487
Rep 10,329
If you track you need something that can go to -2.5/-3 up front. There really isn't a way around it. Camber plates allow you to achieve this |
chocstraw495.50 |
