10-05-2018, 03:06 AM | #1 |
Rep 42
Idle issue with 550 kit
Hi,
Anyone with an ESS kit run into this issue? I’ve got a 2011 e90 with a 550 kit installed brand new last year. Got several thousand miles on it already. Right after the cold start, the idle would fluctuate, then go away once the car is warmed up. Plugs are under a year old. It's done this since day one. Any ideas? Thanks.
2011 E90 SSII ZCP, DCT, ESS VT1-550
10-05-2018, 06:35 AM | #2 | |
Rep 4,014
10-05-2018, 09:48 AM | #3 |
Rep 1,263
Do you see any fluctuations after filling up the tank?
I would start with the breather valve as Boof mentioned. Also, the service interval is 7.5k to 10k for the spark plugs. Change them if they are more than that. |
10-05-2018, 10:07 AM | #4 | |
Rep 1,566
I agree with Boof, change the breather valve.
10-05-2018, 01:54 PM | #5 |
Rep 113
Seems like a very common issue that's frustrating..
I don't think its your SC kit. I have the exact problem with stock engine. I changed out the breather valve like people suggested but problem still arises.. |
10-05-2018, 01:56 PM | #6 |
Rep 994
Next step would be your idle control valve in my opinion.
10-05-2018, 01:58 PM | #7 |
Rep 42
No fluctuations after tank fill ups. It's only after cold starts. Thank you all for the info.
10-05-2018, 03:55 PM | #8 |
Rep 42
Never had this problem when I was NA but we both seem to have the same issue where it only fluctuates after the cold start. I'll replace the BV either way and see what happens. Are you replacing your ICV?
10-05-2018, 04:53 PM | #9 |
Rep 510
I’ve got this issue too with my ESS 625 kit.
On a cold start the idle is very lumpy for a few minutes then settles down once the car is warm. Doesn’t do it in when I start the car from warm. I’ve called it an issue rather than a problem because I suppose I can live with it. Once the car is warm the idle is smooth with no fluctuations. On the other hand if it’s a simple fix I’d like to fix it. |
10-05-2018, 11:19 PM | #10 | |
Rep 113
It's completely normal thru out the day after warm up Seems like a phenomenon for our cars from what I've been reading |
10-06-2018, 05:30 AM | #11 | |
Rep 42
10-06-2018, 05:40 AM | #12 | |
Rep 42
10-07-2018, 08:57 PM | #13 |
Rep 747
I have the same exact problem and it happened exactly when ESS 625 was installed. I was never able to solve the problem. I have asked some tuners and said slight idle bouncing at cold start is nothing to worry about but to me that's a problem and can't find what is causing it.
FYI, I replaced BV with new one but it didn't help at all. |
10-08-2018, 09:51 AM | #14 |
Rep 55
Same thing here. ESS 650 kit. Asked many people and no one could give a precise answer. Been living with it for the past 5k miles. It's annoying, but I've never had any problem.
2012 E92 M3 ESS VT2 650 - Bilstein B16 Damptronic Coilovers - Brembo 380mm BBK - Innotech Catless Exhaust - GTS Carbon Wing - RollCage - Back Seat Delete - Sparco Evo Racing seats @m3boosted
10-08-2018, 10:49 AM | #15 | |
Rep 42
10-08-2018, 12:04 PM | #16 | ||
Rep 55
10-08-2018, 01:04 PM | #17 |
Rep 1,131
I had the same issue when I put my Gintani kit, if you have a weak Idle control valve the supercharger will push it overboard and cause it to exhibit issues.
Gintani Supercharger/ Gintani x-pipe/ Challenge rear muffler section powder coated black/ Alpine DCT Tune & Coding/ Republic Werkz modded headlights and tail lights/ Gloss black cosmetics, hood vents, and mirror caps/ Piano Black interior trim, Roof painted black by Ranz Motorsports/ Velos Designwerkz Solo V's/ KW V3's/ MRF Solid sub-frame bushings W/ Delrin Diff bushings/ Duke Dynamics CSL Trunk/ Euro bumper/ Full Dinmann aero kit.
10-08-2018, 01:35 PM | #18 |
Rep 42
Thanks for the info. So at one point does yours fluctuate if you don't have the cold start? I asked ESS about the cold start delete but they advised against it.
10-08-2018, 01:37 PM | #19 |
Rep 42
So did you replace your ICV and it fixed it?
10-08-2018, 02:38 PM | #20 |
Rep 1,131
10-08-2018, 04:01 PM | #21 | |
Rep 55
It goes away after 2 minutes or when car is already warmed up. Only happens in cold start.
10-08-2018, 11:24 PM | #22 |
Rep 42
That's good to know! Did you replace it yourself? Any tips? I found a DIY thread for it.
https://www.m3post.com/forums/showthread.php?t=842102
