02-17-2019, 11:43 PM | #1 |
Rep 21
Dinan Lower Control Arm Monoball Kit
Is there any one that has replaced the rubber bushings in the thrust arm with Dinan Lower Control Arm Monoball Kit and is not happy?
02-18-2019, 02:26 AM | #2 |
Rep 2,342
Are you unhappy?
02-18-2019, 05:19 PM | #3 |
Rep 2,824
I’ve read probably every post on the part and nobody seemed unhappy with them.
Bimmerworld also popular. Turner has some clunks. |
02-19-2019, 11:37 AM | #4 |
Rep 1,617
Weird.. I got turner ones and they broke on me after 3 track days. Got Dinan ones and have no issues with them. Happy with them.
02-20-2019, 12:33 AM | #5 |
mTekMods
2142
Rep 2,901
I’m running the Fall line front thrust arm monoball. No strange noises
02-20-2019, 08:38 AM | #6 |
Rep 114
German Auto Solutions. They are GREAT
ARC-8 Wheels - Stoptech Trophy BBK - Solid Subframe Bushings - Purple Diff Bushings - Topspeed X-pipe - Megan Catback - AFE Carbon Intake - RE Pullies - BPM Tune - GAS Monoballs - ECS Front Sway - GTS Wing - Autosolutions SSK - Vibratechnics Motor Mounts - Revshift Tranny Mounts - VAC Bearings - Bilstein PSS10 Coilovers - Dinan Camber Plates - Ultra Front Strut Bar - BSW Ghost Subs - Matek Diffuser
02-24-2019, 11:53 PM | #7 |
Rep 500
I am happy with the Dinan ball join.
More solid than stock, improve front stiffness. FYI, I am still on stock sway bar (e92) |
03-02-2019, 07:39 PM | #8 |
Rep 619
Just picked up a set of German auto solutions. I'll report back once I install them.
03-03-2019, 04:25 AM | #9 |
Rep 6,285
GAS monoballs are high quality crafted items that are much cheaper then the dinans!
So glad to see more and more people using them great Co to deal with also |
03-03-2019, 05:05 PM | #10 |
Rep 619
Hey there, how did you remove these?
03-03-2019, 07:04 PM | #11 |
Rep 94
Has anyone experienced any noise (clicking, squeaking, etc.) on either the Dinans or GAS Monoballs?
2012 E92 M3 ZCP Jerez Black/Bamboo
2020 F90 M5 Comp British Racing Green/Tartufo |
03-03-2019, 08:54 PM | #12 |
Rep 6,285
03-03-2019, 08:55 PM | #13 | |
Rep 6,285
Most guys I know say no more noise a tiny bit more NVH though. (I had a heap of things changed at the same time with stiffer engine mounts, new clutch and SMF, new coilovers, new rims/tyres so i cant personally provide you with feedback) Do you have issues with a set thats been installed, or are you seeking feedback prior to purchase? |
daarts38.50 |
03-06-2019, 04:32 PM | #14 | |
Rep 94
03-06-2019, 04:42 PM | #15 | ||
Rep 6,285
they're exactly the same, they both utilise OEM internals with just a unique case for each. in this scenario GAS is a lot cheaper for essentially the same product |
03-07-2019, 07:34 PM | #16 |
Rep 94
Perfect, thanks for the help!
03-10-2019, 09:41 AM | #17 |
Rep 619
I installed the GAS bushing and it feels better, not great. I was expecting to remove some shake in the steering wheel while driving above 80 but this didn't happen. If it did, it was minimal.
With regards to braking, it feels much better when slamming on the brakes. There's no more shimmy from the front end and so no steering wheel shake when braking. I feel more confident when braking and I appreciate that. do feel that the car is turning better while on the highway, no mountain carving yet, I feel that the car moves better when switching lanes and it seems dartier. Which is a good thing! When turning into a corner, the car feels stable and rigid. Again, all good things! The install is easy if you have the right tools. I recommend replacing the bolts and nuts. |
oolas3388.00 CurbBender'9071.50 |
04-29-2019, 12:21 AM | #19 |
Rep 619
01-02-2020, 06:44 PM | #20 | |
Rep 4,164
Hopefully it will last longer than the stock bushings. Otherwise it may not be a worthwhile mod for daily drivers. |
