      02-01-2019, 02:40 PM   #1
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
KW Clubsports Rear Rebuild / Shock mount Question
Hello,
Will be buying a set of KW Clubsports second hand and sending them to KW to be re-built.
I am looking to change the rear shockmounts during install. My current car is EDC. I am correct in assuming I will need to buy new Non-EDC shockmounts to mate with the KW CS?
Also, is there anything else that I should be replacing at this time?
Thank you!
      02-14-2019, 04:24 AM   #2
blk rex wagon
Drives: 2004 e46 m3, 2011 e90 m3
It depends on which version KW CS you bought.. they make a EDC version and non EDC version. That will be the mount you'll need to buy for the new shock mount
      02-14-2019, 09:21 PM   #3
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Non edc shock mount from power flex doesn’t fit on the KW Clubsport non edc rear.
      02-15-2019, 11:15 AM   #4
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
Got it, so If I get the non EDC clubsports then I need the non-edc RSM.
      02-28-2019, 05:40 PM   #5
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
I called KW today. One of their reps said that I would need an EDC rear shock mount even if the KW CS are non-EDC because my car is EDC???
      02-28-2019, 06:09 PM   #6
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11480
the car's mounting points are identical. The difference is the thickness of the shaft between EDC and non EDC
      03-25-2019, 04:11 PM   #7
M3 Number 86
Drives: black m3
hmmm....buy 10 and 12 mm rear RSM and see which one fits, then return the other one. My car was edc but can't remember which ones i went with.
      03-26-2019, 12:37 AM   #8
Bartledoo
Driver
Bartledoo's Avatar
2692
Drives: 2011 E90 M3 6MT
That doesn't make any sense. The difference between EDC and non is in the shock's rod diameter and corresponding mount, not in the chassis.
If you have KW CS for EDC, then the rod diameter will be wider requiring the EDC specific shock mount which fits the wider diameter.
If you have the CS for non-EDC, then the rod diameter will be narrower requiring the non-EDC specific shock mount which fits the narrower diameter.
      03-26-2019, 07:52 AM   #9
turbo_joe
turbo_joe's Avatar
1614
Drives: 2012 M3 Coupe
I just installed my Kw Clubsports yesterday (EDC version in car with EDC)
I went with the Dinan shock mounts (EDC version) as NON of the mounts from powerflex worked. The rear shock shafts are 14mm on the KW Clubsports and so are the OEM EDC M3 shocks. Powerflex only makes a 10mm and 12mm mount. I know this because I order the powerflex mounts first and had to send them back.
https://www.dinancars.com/product/d1...93-edc-only-2/
