10-12-2020, 10:58 AM | #1 |
Rep 39
M3 E92 timing chain
hi guys,
The M3 uses timing chains, not belts. They're supposed to last the life of the car. That's regular standpoint of BMW. But is it really true? Because they also recommend to change the oil after 15k mil... I have on mine M3 E92 from 2011 60k mil, so I change rod bearings now. And the timing belt is really immortal? I'm driving very gently, till 2500 rpm before motor is warm, no races... Generally, if the chain isn't in god condition and is already pulled out (a little bit bigger), you can hear rattles while idling, or some clicking noise, right? |
10-12-2020, 02:32 PM | #2 |
///M Powered for Life
11469
Rep 10,328
The S65 timing chain is for all effects and purposes immortal
10-12-2020, 03:40 PM | #3 |
Lord Scrip
1812
Rep 3,012
Drives: 2011 M3 Coupe
I am not the most knowledgeable here but I have read threads about the timing chain guides wearing and allowing too much slack in the chain and that being an issue. I would then wonder is this based on how the car is driven (hard/soft).
10-12-2020, 08:09 PM | #4 |
Rep 2,907
Drives: 2011 E93 M3
The chain will outlast your car. I've only come across a couple with link wear enough to warrant considering replacement.
The chain isn't the source of startup noise. Worn oil check valves throughout the engine contribute more to that. |
10-13-2020, 02:56 PM | #5 |
Rep 2,138
Drives: 2011 E92 M3
^ as said above, the chain clatter at startup is just the delay when waiting for the tensioner to re-pressurize.
Timing chains in the S65 are robust. They are not prone to failure like some of the other BMW V8s, such as the guide issues in the older 7 series vehicles. My car clatters a little every time I start it after sitting for a day or two. No big deal. Cheers,
SYT_Shadow11468.50 |
10-13-2020, 09:04 PM | #6 |
Lord Scrip
1812
Rep 3,012
Dean are there more than 8 non return valves?
10-14-2020, 10:51 AM | #7 | |
Rep 801
10-14-2020, 06:39 PM | #8 |
Rep 9
M3 Noise
I'm having the same issue, but i have no idea if this is the same sound you are getting. Does it sound like a thik thik thik sound?
video - http://vimeo.com/468352210 |
10-16-2020, 05:57 AM | #10 | |
Rep 1,180
Drives: 2011 E92 M3 6MT ZCP
In the early 90's GM had a similar problem in some of their 350 engines and a simple check valve prevented all of the oil from draining back into the sump. I don't think it is piston slap, sounds to me like the timing chain going across guides that maybe don't have enough lubrication yet. |
10-16-2020, 06:03 AM | #11 | |
mTekMods
2124
Rep 2,888
usually being the vanos adjuster that rattles or makes a clank on cold start which goes away in a second once oil pressure has been built.
chocstraw495.50 |
