08-07-2014, 04:41 PM | #1 |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Is this an oil leak?
I was checking out the engine bay today and noticed this:::. Should I be concerned with this, it was all dry last time I checked and now looks like oil is seeping through! No rough riding, no rough idle no problems at all and I wasn't diving it hard either! thanks for your input~
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
08-07-2014, 04:47 PM | #2 |
Bad Lieutenant
233
Rep 3,517
You'll have to clean that off and keep an eye on it as it does look like oil or residue.
08-07-2014, 04:50 PM | #3 |
Grown Azz Man
430
Rep 3,021
Valve cover gasket.......as stated, clean it up and watch it............Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
08-07-2014, 05:19 PM | #4 |
Rep 701
Anytime you see oil or wet spots pooling around an area..it's a leak.
They don't get better, they only get worse. So I am not sure I understand the logic of "watching it". |
08-07-2014, 05:35 PM | #5 | |
General
63420
Rep 24,687
08-07-2014, 06:44 PM | #6 |
Rep 2,792
The beginning of the end for your valve cover gasket.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
08-07-2014, 07:30 PM | #8 |
Rep 1,260
yup,..valve cover leak. I have the same problem but my leak..or leaks are coming out of the gasket around the bolts and not the actual gasket itself.
I would wipe it off and see where the leak is. if it is the cover gasket ....as M3PO said .....it's the beginning of the end of the gasket. It will get worst.
08-07-2014, 08:11 PM | #9 | |
Rep 2,716
Drives: M3
08-08-2014, 06:16 AM | #10 |
General
63420
Rep 24,687
Maybe this would help....
Try re-torqing the bolts....and make sure to get the torq. specs for the bolts ? So what do you think about re-torqing the bolts ?
08-08-2014, 07:18 PM | #11 |
Rep 701
If you've dealt with perished gaskets then you know tightening or re-torquing the bolts generally makes the leak worse.
08-08-2014, 11:29 PM | #12 | |
Rep 1,260
For me the leak is at the top of the bolt and not the seams of the cover and gasket.
