12-24-2016, 05:31 AM | #1 |
Rep 130
Had my rod bearings done at Tuning Dynamics Tampa
Best shop I've found in Tampa. My bearings were on borrowed time. Some were on its last legs. Clicking noise wasn't noticable.
2011.1 e92 m3. Done at 68k miles. All bearings close up 1 close up 2 Andrew and Paul took really good care of my car. Last edited by BLuRRYM3; 12-24-2016 at 09:41 AM.. |
12-24-2016, 08:25 AM | #3 | |
General
63342
Rep 24,664
Is your car SC ? Good job and thanks for sharing
12-25-2016, 10:40 AM | #6 | |
Rep 985
Drives: 08 M5 Sapphire Black
1st owner?
12-25-2016, 08:26 PM | #7 |
Rep 130
02-06-2017, 11:39 AM | #10 |
Rep 984
Damn OP, your car is similar to mine. Mine is 2011.5 e92 m3 approaching 57k miles. I always do proper warm up and run LM 10w60. Ive done initial BS oil report at 53k miles and it was fine but that baseline report doesn't mean anything until you do a second one and get a trend.
Also curious if you went with BE bearings and bolts, that's what I ordered.
2004E46M36MTCBCinn 'Clubsport'
04-03-2017, 05:46 PM | #12 |
Rep 8
Just want to bump this thread and provide another positive review for Tuning Dynamics. Even though my bearings only had around 30k on them, it's all about peace of mind. I've only had my car a little over a year, and I don't know how the previous owner drove the vehicle (i.e. redlining while cold!). Mine did show some wear but were otherwise in better shape than most I've seen on the forums.
TD was running a special military discount for March, so I couldn't pass that up. The owner Andrew is very knowledgeable and offered up tons of great information about the M3 and BMW's in general. His tech Paul was also willing to talk at length about my E90 and even showed me some technical things that will make my DIY work much easier. I'll only be DIY'ing stuff because, unfortunately, I'm up by Valdosta. These guys are over 3 hours away from me or they'd definitely get more work from me. There's a reason you take a job like this to guys who know what they're doing. They've done this delicate job over two dozen times and it is evident. Oh and btw Paul who did my car is a highly skilled dude who's a BMW trained tech. They don't put that out there enough, but that should be known. I could go on about these guys, but I don't need to since you should just go check out the shop and talk to them. I also opted for WPC bearings and ARP bolts. They also installed a few other goodies. Once I'm not so busy I'll post up a thread with pics. |
04-06-2017, 06:04 PM | #13 | |
Rep 30
Thank you for the kind words Jeff! It was our pleasure, now go out and enjoy that M3! |
04-12-2017, 09:39 PM | #15 |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
did you have oil analysis done on the regular and what were the values?
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
04-19-2017, 03:35 PM | #16 |
Rep 8
I've been having the oil analysis done, but from what I learned on the forums is if you have the new bearings they do not have the same copper/lead content of older MY bearings. That means oil analysis will not show the same spike of usual materials indicating failure. I could not find any updated information about what to look for. My particular car actually had an engine already replaced at 35k under warranty by a previous owner so I wasn't taking any chances. I auto-x and drive my car enthusiastically and just wanted the peace of mind. I can't find the super long and informative bearing thread, but it's out there. If you need me to find it let me know and I'll search more.
09-27-2018, 05:01 PM | #18 | |
Rep 498
Drives: 2010 E92 M3
Naturally, I'm nervous to let just anyone open up that engine, I can't find anything negative about them, and based on what I've read they seem like they really know their stuff and run a solid operation. They're a little north of us, looks like about 45 mins from me (I'm in the downtown St Pete area) https://www.tunedbytd.com/
2010 E92 M3 // IG: @commuter_blue
09-29-2018, 09:27 AM | #19 |
Rep 185
Drives: 2012 E92 M3
Tuning Dynamics is a great shop. Andrew and his team have been doing all of the work on all my cars for 10 years, including rod bearings and a supercharger install on my current M3. They are very knowledgeable on all things M, and they are very competitively priced. I highly recommend them - they are a bit of a drive, but the service is worth it.
992 C4
10-30-2018, 09:28 AM | #21 | |
Rep 498
Drives: 2010 E92 M3
I ordered an oil analysis kit. It's in my trunk. Haven't done it. Doing rod bearings anyway. Will do an oil analysis before every oil change afterwards. There are a ton of threads around here that will not yield you any sort of answer. Ultimately, you need to determine if the risk of not changing them is right for you, regardless of any type of oil analysis.
11-01-2018, 12:30 PM | #22 | |
Rep 185
Drives: 2012 E92 M3
It’s honestly such a crapshoot I think it’s worth the 2k, even on newer low mileage cars as it happens to all of them selectively.
992 C4
