      07-25-2021, 08:02 PM   #1
e92m3sf
Drives: e92 m3
DSC Malfunction + Limp Mode
I was getting ready to fix my car this weekend for its current coolant temperature sensor:
002AF9 Coolant temperature sensor
002B59 Coolant thermostat monitoring
002AFD Relative time plausibility
And then I threw some new codes today. I was thinking of holding back on the fix and figuring out what's throwing this new code before I attempt the sensor replacement:
2B0D Idle Speed Control Monitoring Bank 1
So the DSC malfunction and limp mode came on when I cold started and went away after restarting the engine. My idle has been kind of rough (especially after getting gas) lately and I was doing some research and it seems it might be the ICV? Could anyone with experience chime in? Part is about $1000 so I just want to confirm this is the issue before I dive in.
Throttle Body Actuators have been changed about 2 years ago along w the thermostat. Sometimes when I get gas, the idle would be super rough with it even shutting off the engine (happened only twice in the past 3 years but hasn't happened recently).
EDIT:
Carly also gave these extra codes that I assume pop up when the main issues arise:
DSC Codes:
D355
D354
5E19
D356
Engine Codes:
2AF9 Coolant Temp. Sensor
2B57 Engine Emergency Program Activated (limp mode?)
2B59 Coolant Thermostat Monitoring
