07-22-2021, 12:52 PM | #1 |
Rep 228
Drives: E90 M3
Installing Resonators into an X-pipe
Hi! I recently purchased a used bimmerworld x-pipe with the forward facing x-pipe and no resonators. Unfortunately there is a rasp sound I do not like, so I purchased some vibrant resonators. Where is the best place to put the resonators? I do not want to put it before the x-pipe so I don't disrupt the exhaust flow in any way before the "X." I was contemplating on putting it soon after the "X" because I thought it would prevent any travel of high frequency vibrations (rasp) further down the pipe, but I looked at bimmerworld's resonated version and they placed it all the way at the end for some reason. Any inputs would be nice, thanks. |
07-22-2021, 01:13 PM | #2 |
///M Powered for Life
11469
Rep 10,328
I'd put it after the X. Look at a stock xpipe and you'll see where there's space for resonators. You could probably put 3 per exhaust bank if you put them in place of the primary cats, secondary cats and resonators of the oem xpipe
07-26-2021, 10:25 PM | #3 |
Rep 228
Drives: E90 M3
Just an update!
I would like to say it was a success! I had the non-resonated BW x-pipe and it had a rasp whenever one applied decent throttle. This rasp usually began around 2k rpm. Once I installed the Vibrant 1792 bottle resonators, I'd like to say most of the rasp is gone! I say most because I hear faint remnants of the rasp when I upshift around 2.5-3k. When I apply a medium-hard amount of throttle, the rasp is 99% gone. I can hear a really faint rasp but I have to be honing in and focusing on hearing the rasp, which no one does. That being said, if someone has the resonated version and has the rasp, the rasp will probably be gone with another set of resonators. I placed the resonators soon after the x on the x-pipe. I have no clue why BW put the resonators at the end. Video recording this weekend.
yt:itoto
insta:@m3.toto |
atopa2002202.50 |
07-27-2021, 02:48 PM | #5 |
Astronaut
514
Rep 732
Instagram | @undisclosedm3
"Never think that you are above taking out the trash." |
07-27-2021, 03:28 PM | #7 |
Rep 228
Drives: E90 M3
@pbonsalb @Vuu: Thanks for the suggestion. Maybe in the future! I didn't weld because of fitment concerns and the thought of being able to adjust the tube length if necessary is appealing. I've been using lap-joint clamps, so far they seem to be holding the exhaust in.
@Powashiftin: Interesting! CNT mufflers, I love the loud and bassy tones. I'm glad you don't have the rasp, but from looking online, I also hear the rasp from this guy's Corsa (Link: https://www.m3post.com/forums/showthread.php?t=1540486). If you want specifics, in the "Corsa cat-back exhaust in car," you can hear the rasp starting at 2:04-2:07 and 3:45-3:36. He speeds through the rasp rpm range so it is not exaggerated, but if one were to maintain that rpm and throttle, the rasp will persist. I'm sure there are other timestamps where this occurs. And if one thinks it's the heat shield vibrating, trust me, I tried to test/correct that before adding the resonators. In addition, from looking online, the x-pipe also have rasp with Dinan. (Link: https://www.m3post.com/forums/showthread.php?t=1760861) Last edited by itoto; 07-27-2021 at 03:35 PM.. |
07-27-2021, 07:43 PM | #8 |
Rep 4,157
Probably to keep exhaust gas velocities high for performance. Putting a resonator closer to the engine will create more back pressure than placing it further downstream.
07-27-2021, 08:12 PM | #9 | |
Rep 228
Drives: E90 M3
yt:itoto
insta:@m3.toto |
07-27-2021, 10:29 PM | #10 | |
Rep 957
Whatever makes you happy ! |
08-01-2021, 10:08 PM | #11 |
Rep 228
Drives: E90 M3
pls excuse the wind noise on some parts, newb gopro user timestamps are included in the vid yes i use my blinkers Last edited by itoto; 08-01-2021 at 10:12 PM.. Reason: add more words |
a5m611.00 |
