07-24-2018, 07:45 AM | #1 |
Rep 423
OEM pads on track
Could someone post their experience with OEM (textar) pads used on a track day? Do they fade immediately or hold up somehow? I went on a track day with Hawk HPS 5.0 and they faded every session after 2 2-min laps. Going full track pad makes no sense for me, as I daily the car and go to the track 1-2 times a year just for fun.
The Hawks had less bite when cold than oem and ate the rotors on the track. If stock pads will hold up just the same, while being more gentle on rotors and providing a better bite, then I would probably want to go that route. Btw, from my point of view the oem brakes would do just fine if they had some decent cooling.
07-24-2018, 08:48 AM | #3 |
Stop the hate, get a V8
3851
Rep 8,625
OEM pads are not for the track and will perform the same as the Hawks. I tried them once, they disintegrated.
If you are going to use a non-track pad on the track, you won't be able to drive as hard, as fast, or for as long. You'll also need to mind your braking technique which kinda takes all the fun out of it. The OEM pads will be fine for a few laps, but then you'll want to take a cooldown lap or two before getting on it again.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 07-24-2018 at 09:39 AM.. |
07-24-2018, 09:04 AM | #4 |
Rep 114
I've had really good luck with PFC Z-Rated pads. I have run 4 track days on them and they have held up surprisingly well. They are great on the street. I keep planning on swapping to track pads for HPDE events but the Z-Rated keep performing. You can pick them up at O'Reillys for cheap too. Have you changed your fluid to a higher performing one? I run Motul 600 and that made a drastic improvement on fade at the track.
DrFerry6730.00 |
07-24-2018, 07:45 PM | #5 | |
e90noob
1588
Rep 1,864
and your track pads should last you a last time then
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
07-25-2018, 02:16 AM | #6 |
Rep 423
My last experience was just like @dparm has described. I had to brake earlier and earlier and was losing confidence.
I will look into these z rated pads, but so far I think the best solution would be stock pads for daily and some track dedicated ones for swapping on a track day. Do you think I could swap just the fronts then?
07-25-2018, 08:09 AM | #7 | |
3851
Rep 8,625
Yes, that would probably be fine. The rears are not doing a ton of work anyway.
Past: 2011.5 M3 sedan ZCP |
07-25-2018, 09:53 AM | #8 | ||
Rep 423
One more thing - how are oem rotors holding up after a track day with track dedicated pads? Aren't such pads very hard on rotors?
07-25-2018, 12:03 PM | #9 |
3851
Rep 8,625
One track day with a race pad on OEM rotors isn't going to destroy them.
07-25-2018, 05:34 PM | #10 |
Rep 818
Track pads are more abrasive when you run them on the street since they do not get hot enough to work properly. That said, it's all relative. Even if they were twice as abrasive as street pads, your rotors would still last a very long time if you did a lot of street driving with your track pads.
07-27-2018, 11:27 AM | #11 | |
Derbo Tuning
3610
Rep 3,025
lutfy said he could get PFC08s worn out in one weekend on OE rotors and when he switched to PFC DD rotors, it significantly decreased the pad wear rates.
IG:ruhrohz_m3
07-27-2018, 11:38 AM | #12 | |
3851
Rep 8,625
I should have been more clear. You will not wear the OEM rotors from new to minimum thickness in one track day on a PFC08, but it's very possible to wear the pads down pretty far depending on the track, your driving style, and the car setup (namely if you have more power and/or R-comp tires). If the OEM rotors can't dissipate heat fast enough, either add more cooling or run pads with a higher MOT.
derbo3610.00 |
07-27-2018, 11:40 AM | #13 | |
3851
Rep 8,625
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 07-27-2018 at 12:54 PM.. |
bigjae19761578.00 |
07-27-2018, 12:57 PM | #14 | |
Derbo Tuning
3610
Rep 3,025
IG:ruhrohz_m3
07-27-2018, 06:25 PM | #15 |
Rep 8,077
Drives: 11 E90 M3 Individual
Which is why there is no such thing as a true dual purpose pad.
2018 F30 320iX Melbourne Red
07-28-2018, 08:08 AM | #16 | |
Rep 423
In my case the best solution seems stock for the street and some serious track pads to swap. I can't imagine overheating stock brakes on the street to be honest, they gave up on the track after 2 laps with some 200-100 hard (sometimes trail) braking. Not possible to drive like this on public roads
07-31-2018, 12:49 PM | #17 |
Track? What Track? I was just riding along . . .
46
Rep 694
My friends and I have been using StopTech Sport pads for a few years on various cars for arrive and drive track pads. (They used to be called StopTech Street Performance but the name got changed around the first of the year. DON'T get the new StopTech Street brand.)
They seem to have about the same stopping power as a street pad, but they don't melt or fade during HPDE duty. We can get them off Amazon and they're cheap compared to a dedicated track pad. |
