08-14-2018, 07:07 PM | #1 |
Alpinweiß Herrenrasse
15
Rep 92
Drives: 2013 M3 Coupe, 2000 750il
KW HAS Rear Spring base spins with collar
Perhaps I’ve done something wrong, but when I try to adjust my spring height, the black threaded base spins with the coilover wrench and adjustment collar. I have tried gripping the base with my oil filter wrench, but it’s too thick to allow the coilover wrench in. Any ideas or am I stuck taking this all apart again? Lol
08-21-2018, 02:58 PM | #2 |
Rep 3,735
You need to remove the spring and the adjustment collar to make adjustments. You will not be able to turn it easily while installed into the car as the KW HAS kit spring in the rear is under a lot of load even at fool droop.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
08-21-2018, 06:20 PM | #3 | |
Rep 1,485
Drives: 2011 Frozen Grey E90 M3
Lame!
08-23-2018, 12:12 PM | #4 |
15
Rep 92
I ended up using a few dots of super glue to keep the base from spinning, and that did the trick nicely. Couple blows with a mallet should dislodge it if I ever decide to change setups.
