01-31-2017, 01:36 PM | #1 |
Rep 466
PCV ?....is it hidden?
Hi. Am in the process of changing my TA and currently have the plenum off. Since I"m in there, figured I'd change out my PCV valve. However, I can't seem to locate it. If I start tracing back from the oil return hose (the one that connects to the intake)...it disappears around cylinder 5-6 ..
Is the PCV way in the back of the engine? Anyone change it before? Thx. |
01-31-2017, 06:16 PM | #3 |
Rep 1,389
Drives: 2012 E92 M3
I didn't know modern cars still had these. I would think you would see it sticking out of the valve cover like they did back in the day..
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) |
01-31-2017, 11:13 PM | #4 | |
Rep 466
The crankcase return hose connects to this and the other end connects to the air intake plenum in the front of the car. Problem is if I follow this hose to the back, I lose where it goes at seems to take a nose dive under the cabling near the throttle actuators. |
01-31-2017, 11:26 PM | #5 |
Rep 1,263
Don't know if this helps, but it's item #2 in this diagram.
http://www.realoem.com/bmw/enUS/show...17#11617836553 |
01-31-2017, 11:31 PM | #6 | |
Rep 466
02-01-2017, 02:17 AM | #8 |
Rep 466
02-01-2017, 08:54 AM | #9 |
Rep 62
It not a conventional pcv valve system on the s65: it's a baffle type system in the valve cover that separate the oil vapors and oil droplets.
02-01-2017, 11:40 AM | #10 | |
Rep 466
What I'm referring to is the Crankcase Valve. ECS Tuning calls it the PCV but it might be just a breather valve. Sorry I don't have a better pic on me, but on the pic below, the ventilation hose (one circled in yellow) is where it starts (connection to the plenum). The problem I'm having is I lose where the hose goes as it gets back into the engine block. Am trying to get better info on where the ultimate connection is on the valve to the block (before I randomly start tearing back stuff). https://www.ecstuning.com/b-genuine-...e/11617836553/ (Pcv valve) https://www.ecstuning.com/b-genuine-...e/11617838288/ (Crankcase vent hose that connects to the PCV) |
02-01-2017, 12:08 PM | #12 |
Rep 466
02-01-2017, 02:44 PM | #13 |
Rep 252
Without removing several components from the top/back of the engine you wouldn't be able to get to it. If I remember correctly you would need to remove the engine wiring harness on that side plus the egr hose. It might be accessible from the bottom, but it would be tough considering it is on the topside of the transmission housing.
02-01-2017, 03:04 PM | #14 |
Stop the hate, get a V8
3851
Rep 8,625
Depending on the specific design, they eventually wear out. See below photo for a simple explanation.
Obviously, the spring is fatigued over time and doesn't rebound correctly (or at all). The diaphragm can also get jammed or so dirty that it doesn't move enough.
Past: 2011.5 M3 sedan ZCP |
02-01-2017, 03:27 PM | #15 |
Rep 62
The n65 engine does not have a typical pcv valve: the sytem uses two oil seperators where the valve covers and intake meet. Oil accumulated after this process in the intake goes through the front bottom of the intake and then through the tube discuss before on this topic. After there is a oil drain back valve that brings back the oil in the crankcase.
02-01-2017, 03:46 PM | #16 | |
BMW CCA member and you should be too!
217
Rep 478
02-01-2017, 07:00 PM | #17 | |
Rep 466
02-02-2017, 03:49 PM | #20 |
Rep 466
02-04-2017, 10:28 AM | #21 |
Rep 8,076
Drives: 11 E90 M3 Individual
That's definitely a recipe for some cuss words and scraped arms!
2018 F30 320iX Melbourne Red
