03-08-2009, 04:33 PM | #1 |
Rep 81
Jerez Black Detail Question
I just purchased a remaining 08 Jerez Black on Fox Red Sedan and want to detail the car completely. The dealership prepped the car but it has some minor swirls left over from the washes while it was on their lot. I am looking for some advise on what anyone recommends to use as a polish to buff out the swirls. I just bought some stuff from Chemical Guys and would like to know what pads, polishing compounds, techniques to use. I will try and post some pictures of the swirls.
Here is what I bought from Chemical Guys: Citrus Wash & Gloss JETseal109 Clay Bar (MEDIUM DUTY) Gray and Detail Lube Bare Bones UnderCarriage Spray Wheel Guard Wheel Wax Silk Shine Sprayable Dressing Natural Shine 50/50 wax |
03-08-2009, 08:12 PM | #4 | |
Rep 4,318
I have bought from Autogeek.com and have always had good service (put in code "autopia" for 10% off.) Detailers Domain is another option and they are a sponsor here I believe. |
03-09-2009, 02:10 PM | #5 |
Rep 11
I have an e92 jerez black and took delivery immediately when it came off the truck, with the plastic still on it. I always used the utmost care when washing it and still, because the clear coat is so soft, put very fine lines in the paint. I have quite a collection of products now, and used the following to remove the lines...
1. Chemical Guys CWG with a foam cannon and two bucket method with grit guards 2. CG clay bar and meg's final inspection as lube 3. Dry with mf waffle weave and The Absorber chamois 4. First pass polish with Menzerna Nano and White Lake Country Pad 5. Deeper lines/scratches were taken out with Menzerna SIP and green/white lc pads 6. Second pass polish with Menzerna Nano and black lc pad 7. Third polish with Menzerna Glaze and black lc pad 8. Meg's Final Inspection to remove any remaining polish residue 9. Two coats of CG Jetseal 109 with mf applicator 10. Two coats of CG 50/50 wax with small red lc pad done by hand Jerez is a beautiful color but an absolute pain to take care of. The only bright side to my trials and tribulations is that I now know what works to restore the paint and what doesn't. I also used a very fine mist of water to dampen the pads lightly before applying the polish. This seemed to really help in my opinion. Hope this helps mate. PM me if you have any other questions or want pics. Last edited by WIKKDM3; 03-09-2009 at 02:20 PM.. Reason: mistake |
03-09-2009, 05:33 PM | #7 |
Rep 81
WIKKDM3 Thanks for the step by step. I am going to try the steps you stated. I need to buy some of the Menzerna products but everything else I have.
What speeds on the polisher did you use? When you were applying the 50/50 did you apply it with your bare hands and then take it off with the pad or put it on with the pad and take it off with a microfiber cloth? Thanks again for all of the help. |
03-09-2009, 08:01 PM | #8 |
Completely obsessed with detailing
299
Rep 15,442
Drives: E90 SG 330i, white Scion tC
SIP should be fine for your car. just finish it up with 106FF and/or PO85RD. PO85RD's gloss is amazing!
03-09-2009, 08:59 PM | #9 |
Rep 4,318
I thought 106FA was the replacement for PO85rd? I also don't recommend something with too much cut and I think SIP would be too much for "minor swirls", especially with the soft clears we have.
03-09-2009, 09:14 PM | #10 |
299
Rep 15,442
106FA is basically 106FF which has more bite than PO85RD. PO85RD is such a fine polish that it just about has no bite at all. SIP won't take that much paint off anyway. If 106FF works, you can skip SIP, but on most dark colors I've worked on, SIP was absolutely necessary even on new paint.
03-09-2009, 09:42 PM | #11 |
Rep 11
Absolutely agree that on dark cars the menzerna sip will need to be used. But, in my opinion, I doubt the entire car would need it, most likely just the trouble areas, such as the front fenders, hood and bootlid. I always start with the least cut and then work backwards, as there is no point removing more microns of paint than necessary or to make your job more difficult by cutting the paint to much. Just my 0.02.
03-10-2009, 03:38 AM | #12 | |
Rep 165
03-10-2009, 02:09 PM | #13 |
Super modder
104
Rep 1,973
nice, taking note on this post for down the road....the car will need some work down the road but very clean as of now.
THanks for the post! M
SOLD - 2005 E46 M3 ZCP - I/B on black CURRENT - 2011 E90 M3 - meticulously modified 2015 X1 Xdrive 28i |
03-10-2009, 08:38 PM | #14 |
Rep 1,504
I found this to be true as well.
'09 E92 M3 6MT | Alpine White | Black Leather | EDC | CL Trim | 19s
'03 E46 330i 6MT | Electric Red | Black Leather | ZSP | Bi-Xenons |
03-18-2009, 01:08 PM | #15 | |
Rep 1,043
Are you using a rotary polisher or random orbit? |
03-29-2009, 02:26 PM | #16 |
Rep 11
On the areas needing the sip, I tend to use a direct drive polisher with a trigger on number 3-4. For the rest of the areas needing only Mernzerna Nano or Menzerna Gloss, I used a porter cable random orbital or my griot's random orbita. I will be purchasing a 4 inch pneumatic polisher for the hard to get at areas in the future.
03-29-2009, 07:01 PM | #17 |
Rep 13
WikkdM3 has it absolutely spot on.
This is the process used to restore the 2009 M3 in my previous post, and it is the ONLY process that I recommend. In order to remove the factory/delivery/lot swirls, I used my Milwaukee direct drive and Lake Country 6.5" pads. Make sure you pick up the proper backing plate, with an angled edge. TAPE EVERYTHING OFF first. Once the surface is clear, move back to your Porter Cable and graduate to the Nano when you can. If the swirls are at a minimum, you might be able to skip the direct drive step, but it is up to you and your time schedule. Direct drives can cause huge errors in the hands of low experience users. Beware. Please remember to tape everything off first, before using one of these machines. Tape $6 Repainting $thousands. Not making mistakes? Priceless! |
03-29-2009, 08:32 PM | #18 | |
Rep 280
'09 E92 ///M3 | Jerez Black/Black Leather | Sycamore Anthracite | MDCT | Premium/Tech/Cold Weather Packages | 19" | Moonroof | Enhanced Premium Sound |iPod/USB | Smartphone
'97 E36 M3 Sedan Hellrot Red/Black; '03 E46 330Ci Met. Gray/Black; '06 E46 330Ci ZPF Imola Red/Saddle |
03-30-2009, 02:35 AM | #19 |
Rep 13
How Often?
The above process is used to bring a vehicle back to a state of Awe from defects in the paint.
It isn't something you can do in an afternoon, it takes more like 2 days on a Black BMW (from defects on most panels) Should your car be closer to fine, use a new piece of clay then move to the Menzerna Nano. It should tell you pretty quickly how bad the swirls actually are. If they vanish, keep going. If not, PM me. |
03-30-2009, 09:57 AM | #21 | |
Rep 1,043
Couldn't you use Nano and then do a glaze? Or will a glaze not do much to conceal on a black car? Just a thought, in the efforts to preserve the clearcoat thickness... I've heard from some people that glazes make sealants less effective though because they dont allow proper bonding, is this true of all glaze/sealants combos? |
03-31-2009, 03:14 AM | #22 |
Rep 13
Opinion
The option of using Menzerna Nano first depends entirely on the buffer/pad system you are planning on using. After a clay procedure you will inevitably add fine scratches to the paint. Since these need to be removed, and depending on the cut of the clay, will show you the pad/polish to use. It is all subjective and at the same time dependent on experience.
My best guess on a clean paint surface is to use the Porter Cable random orbital set at 50% with a Green Lake Country polishing pad to see how it best removes swirls. If it doesn't "cut it" (pun intended), move up to the Green Cutting/Polishing pad with the Nano. If THAT doesn't do it, it would be better to PM me with photos of a light reflection or direct sunlight reflection. You might need to move up to Menzerna PO85U or even PO91E. It all depends on the buffer/pad/polish that you have on hand. Since speed also is a factor, maybe you just needed to give it more umph.. Random Orbitals tend to leave ghosting on the surface if used incorrectly (FYI) (Cyclo Dual Orbitals do not) That is why I recommend using the Lake Country White or Gray pads depending on the color of the paint to finish the surface to a high degree of reflection. (and Nano). Take photos, PM me and I offer my advice freely. (read: Opinion!) As for glazes. At the moment I am not convinced on the need for a glaze IF you are prepping the paint to a fine degree of polish. Glazes tend to hide defects (their main purpose). Remove the defects and no glaze should be required. Traditional Carnuaba waxes are of such quality as to add incredible depth to any paint color, completely negating the need for a glaze. I prefer a sealant over a glaze. So which is better? My opinion... A sealant and a high grade wax. NEVER, EVER trust an auto dealership with a sealant BTW. Glazes are good for a few hours at most, unprotected by a barrier of wax. 5 year Sealant Never Wax your car again? This is rant waiting to happen, eh? The bottom line is to treat your paint surface well, polish it as needed and you should not have to concern yourself with removing too much clearcoat with a random orbital and Menzerna Nano or Micro Polish (PO87MC). At the most it would remove a small fraction of a micron each time, and you should have at the minimum of 55 microns of clearcoat on the shallowest of places. With Menzerna Micro Polish PO87MC and a random orbital used correctly this equates to +150 deep polishes. Last edited by Apollo Auto Detailing; 05-30-2009 at 08:47 AM.. |
