      03-29-2023, 03:35 AM   #1
Lord_E90
Lord_E90's Avatar
Drives: 2008 E90 M3
Varis Install on E90 M3
Hello Everyone,
I recently got a Varis rear diffuser for my E90 M3 and was curious if anyone has either a step by step or detailed installation for this?
Thanks in advance
      04-01-2023, 12:30 PM   #2
Sublivion
Sublivion's Avatar
Drives: 2008 E92 M3
Originally Posted by Lord_E90 View Post
Hello Everyone,
Thanks in advance
https://www.m3post.com/forums/showthread.php?t=1961706
      09-16-2023, 05:32 PM   #3
nyc_dude
nyc_dude's Avatar
Drives: 09 //M3 e90 Interlagos Blue
You should be able to get the installation instructions online in Japanese.
If you have the CF undertray and no hardware, then you need to order the HW from Varis. The Varis undertray is made for an E92 M3 coupe, so there are different holes that have to be drilled for an E90 M3 Sedan.
If you want to run a rear diffuser on your E90 M3, you have to find one like the 3D Design diffuser made for a E90 M3.
I am installing a Varis Undertray on my E90 M3 Sedan in Fall 2023 ay my favorite shop, so fingers are crossed. It is expensive to PPF and ceramic coat a Varis Undertray and Rear Diffuser. dd 50% of the cost of each CF piece for the PPF.
Bulletproof Auto in LA is the Varis distributor in the USA. They can do the PPF and ceramic coat, since they have an in house AutoSpa. They also have a sister Tesla Mods company. They are also on the same block as SpaceX and the Tesla Design Center.
Cheers
      09-16-2023, 05:55 PM   #4
nyc_dude
nyc_dude's Avatar
Varis Undertray install on an E90 M3 Sedan requires a tweak to the mounting holes.
The Varis E92 M3 CF rear diffuser won't fit an E90 M3 Sedan. So go Commando Style (without a rear diffuser) or try a 3D Design rear diffuser ($1800 made on demand in Japan via IND).
Note the recommendation to add rainbow titanium accent bolts, available from Amazon.
Cheers
