08-02-2021, 11:56 AM | #1 |
Rep 21
DCT transmission violently jerking
Hey guys, i have a 2012 E92 M3. I bought it about a year ago with an existing GTS flash for the transmission. A few months later i added an AA catless X-Pipe and dinan muffler. I have not tuned the car but will be having RK tunes do the tune this week(local to me).
A few weeks after installing the catless x-pipe, i would start the car, let it warm up for 15 minutes befor driving When i put the car into Drive(or reverse), the car violently jerks forward as if i was stepping on the gas(i am not pressing the gas pedal). I leave the car for an hour and it will drive completely normal. Its been happening for a few weeks now and happens every other week. I have the wireless obd reader and it will somtimes read codes that pop up, other times nothing. I will add that the tpms sensor is on. I have no idea how or why this is happening but i'm stuck here and would like to enjoy the car wihtout worrying about getting stuck somewhere. Has anyone dealt with this? Or have a solution |
08-02-2021, 12:21 PM | #2 |
Friends don't let friends ESS
3164
Rep 871
I also have a 2012 DCT with the GTS flash from BPM Sport. But I don't think this is related to your transmission or the programming. I sometimes notice lurching or revving when cold at low RPMS unrelated to throttle position and the 'fix' I find is to turn off the Power button (located next to the gear shift). The Power button, when illuminated, makes the throttle more responsive, essentially making the response curve on the throttle steeper, if you know controls. I wish I could set the Power to off on a cold start, but it's not a big enough deal to get into it.
Other possibilities for you include throttle actuators failing or the idle control valve failing. Sharing the codes it throws is always helpful. Cheers, mate. |
08-02-2021, 01:20 PM | #3 | |
Rep 21
I think i saw another post on here about the same issue a few weeks ago but i dont remember if he had found the answer to the issue. |
08-02-2021, 01:23 PM | #4 | |
3164
Rep 871
If it's so severe you can't drive it, probably none of the 3 things I mentioned. I'd write down the codes and share them on the forum as a next step if you aren't able to determine their cause after accessing Dr. Google. |
08-02-2021, 03:32 PM | #6 | |
Rep 372
08-02-2021, 03:40 PM | #7 | ||
Rep 21
08-02-2021, 04:08 PM | #8 |
Rep 372
If you haven't noticed fluid on your garage floor then likely that is not the source of your problem. Although it could dripping into the pan and not making it to the floor.
I assume if your DCT fluid gets lower than the optimal threshold it would trigger a control message. Last edited by SpacegrayMe90; 08-02-2021 at 04:18 PM.. |
08-02-2021, 04:52 PM | #9 |
Rep 946
Low fluid in the DCT can result in a number of odd behaviors and various codes, so it would be a good idea to check the level as a starting point. These units also leak from the pans or the sleeve on top, but unless it is a serious leak you may not notice until you drop the shield. Mine had no visible leak but there was a fair amount of fluid in the shield and on the pans and hoses. Top off the fluid level and clear your codes and see if that improves things. If not then perhaps have the DCT flashed back to stock and have adaptations cleared and see how it does then. You don't mention miles on your car, but by the sound of that code your clutches may be worn out and the system can't compensate further. Good luck!
DrFerry6728.50 |
08-02-2021, 05:41 PM | #10 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Code 2789… I'll wager it's linked as well as low DCT fluid. Set the shift logic to S5 which runs the DCT pump at a higher pressure - if I recall correctly. Have the fluid level checked. There's a special procedure for doing that.. must be warm, on level ground etc. etc. Clearing clutch adaptations might help - or not..
///M Power-Belgium63359.50 |
08-02-2021, 07:00 PM | #11 | |
Rep 21
08-02-2021, 07:19 PM | #12 |
Rep 6,771
Drives: 2016 BMW i8
Wow sorry sounds awful. Hope you can get it back to normal. By the way the GTS DCT tune is absolute garbage IMHO. Makes the car drive very poorly in daily driving condition. It really should be only used with a larger displacement motor or supercharger where they need more clamping power.
DrFerry6728.50 |
08-03-2021, 09:27 AM | #13 |
Rep 235
dont know if this is related at all but my 6mt would jerk when cold a lot until i swapped the donut gaskets on the down pipe to xpipe connection which smoothed it out a lot
08-03-2021, 09:46 AM | #14 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
So if I understand correctly: The OEM DCT clutch pack was replaced by the previous owner and potentially an after-market DCT clutch pack was installed. Then the previous owner switched back to the OEM DCT clutch pack before your purchased the car? I wonder if he/she just reinstalled the 'old' original OEM clutch pack again? Anyway, my innner 'Sherlock' says to check the DCT fluid level and reset the DCT clutch Adaptations first. I recall reading somewhere that as the DCT clutch packs wear, the DCT ECU uses incremental Adaptations (adjustments) to adjust for the wear of the clutch disk pack. Just my two cents.. Good luck. Just trying to help.
08-03-2021, 10:05 AM | #15 | ||
Rep 21
DrFerry6728.50 |
08-03-2021, 10:08 AM | #16 |
S1N1ST3R
143
Rep 1,174
Definitely have the GTS Transmission flash removed.
And for those who are asking. The DCT is in flawless condition and has been serviced completely gaskets fluid filters etc. Car had Dodson Clutches with Billet baskets for the supercharger setup because the stock clutches would not have been sufficient.
2012 E92 M3 World's Fastest N/A E9X M3 & Stock Motor Supercharged E9X M3 11.49 @ 121.54 10.38 @ 136.04 |
08-03-2021, 10:30 AM | #17 | |
Rep 21
08-03-2021, 04:25 PM | #18 | |
Rep 372
In his videos, while he had the M3, he can be seen blowing the doors off many cars. |
08-10-2021, 07:42 PM | #19 | |
Rep 21
04-04-2023, 12:47 PM | #20 | |
Rep 28
DrFerry6728.50 |
