03-30-2021, 11:05 AM | #1 |
Rep 278
Drives: 2009 E90 M3
new battery for 2009 M3 sedan
I need to replace the battery in my 2009 M3 and it looks like I have two options:
Option 1: go to my local shop (Ultimate Bimmer in Nashua) and it will cost $450-480 to get a new battery installed and coded/registered. Option 2: buy an aftermarket battery with the correct specs for less than half the price, but I would need somebody's help who could register the battery Is there anybody around Nashua, NH that could code/register the battery?? Thanks, George
2009 E90 M3 in Space Gray with Fox Red Extended Leather and Carbon Leather Trim
DCT/Evolve Tune (DCT, Servo, Engine) Cold Weather/ Premium/Technology Packages 18" Apex ARC-8 wheels + Michelin Pilot Super Sports 18" Apex ARC-7 wheels + Michelin Alpin PA4 |
03-31-2021, 05:41 PM | #2 |
Rep 876
That seems like dealer level pricing from an independent shop. I would look for a new indy.
If you buy the battery yourself, I can’t imagine most Indy shops charging more than .5 hour to register. I recommend the AGM battery from advanced auto parts (always google for coupon codes). |
04-01-2021, 06:09 AM | #3 |
Rep 942
What about getting an Antigravity Battery that will save you 40+ pounds over that boat anchor in your trunk now? Pay an indi shop 1/2 hr labor to code it.
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
04-01-2021, 01:24 PM | #4 | |
Rep 420
Drives: E92 335XI (sold)/E92 M3 (sold)
04-01-2021, 01:26 PM | #5 | |
Rep 420
ETA: Jesus christ, $660 for their 24AH and $960 for 60! Fuck that LOL |
04-01-2021, 04:49 PM | #6 | ||
Rep 942
2013 e92 M3
04-01-2021, 04:58 PM | #7 |
Rep 876
Antigravity is a whole different level, but if you’re looking to economically lose battery weight, guys have used Mini and Z4 sized batteries. I believe the Mini sized battery saves 20+ pounds and on the aftermarket costs less than a comparable aftermarket stock size.
04-01-2021, 09:24 PM | #8 |
Rep 942
2013 e92 M3
04-02-2021, 07:59 AM | #9 |
Rep 11,072
The small batteries won’t last as long or be as likely to start in winter. I just buy the most similar spec AGM from the parts store for about $150. To get the most life out of it, you should register it. At least reset battery adaptation. A scan tool like the Foxwell NT510/520/530 should register the battery. There are other tools as well.
Years ago, I ran the ETX30 AGM power sports battery in my E36M3. It lasted about 18 months — through one winter but not the next. The E90 is higher compression and more power hungry. If you park in heated garages and trickle charge when you don’t use the car for more than a few days, a small battery would last longer. I did not do those things. I need practicality from my E90. If I did not, I’d probably run the H5 size AGM and try it out. I am not going to spend $800 on a battery to save 40 lbs. I should lose 20 lbs instead as a compromise. |
DL335D582.00 |
04-02-2021, 09:44 AM | #10 |
Rep 2,392
Get Carly, a good AGM battery with correct CCA and register after changing out the battery. There is literally 3 nuts before you are able to remove the battery.
Pass me if you can.
04-06-2021, 01:32 PM | #11 |
Rep 1,391
Drives: 2012 E92 M3
BMW of Stratham has $100 off battery coupon. I would do that rather than trust some other shop or brand and get the wrong battery.
Give them a call and see what they would charge. https://www.bmwofstratham.com/service/service-specials/
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI) 21 X3 Silver/Black(Wife's) 06 330i Monaco Blue/Black (retired) 02 X5 3.0 Topaz Blue/Black (retired) |
04-12-2021, 09:19 PM | #12 |
Rep 1,570
Drives: 2013 LRP M3 Coupe
I just changed my battery last month with this..
Had a coupon and got it for $179+$20 core charge.I believe it's slightly better specs than OE https://www.autozone.com/batteries-s...cca/319459_0_0 If you don't have a buddy that can register it for you: go to stealership pay someone that can code on a laptop buy Carly for BMW buy a BMW code reader/reset tool that can do new battery registration https://www.amazon.com/AUTOPHIX-Om12...NsaWNrPXRydWU= I's meet up and do it for you but unfortunately I don't have any of the above. |
