INDustry distribution
      08-03-2018, 05:59 AM   #1
Jobe.
Jobe.'s Avatar
70
Drives: BMW M3
S65 Destruction
Backstory:
I purchased this engine from a fellow member.
2011 E90 85k miles. He was cruising roughly 70 mph. Realizes that he lost power and the tachometer is at 0. He coasts to the shoulder and tries to restart the vehicle and the starter just clicks. Engine seized.
      08-03-2018, 07:23 AM   #2
TheRussski
TheRussski's Avatar
109
Drives: Slow
Ouch! We definitely be seeing more and more mains giving out, but the numbers are stil very low
Was he supercharged?
      08-03-2018, 07:43 AM   #3
Helmsman
Helmsman's Avatar
Sweden
1818
Drives: 2011 E90 M3 ZCP
Woah...that looks ugly! Rod shells look better, where they changed at some point Jobe?
      08-03-2018, 08:30 AM   #4
Jobe.
Jobe.'s Avatar
70
Drives: BMW M3
No he was not supercharged. He did replace the engine and put a supercharger on the replacement.
I believe he was on the original rod bearings. Engine had factory 702/703 bearings.
      08-03-2018, 08:34 AM   #5
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
Drives: E90M, E92M, X5, Mini Cooper S
I'm so sorry to see that! It is such a shame
Jobe.69.50
      08-03-2018, 08:37 AM   #6
Jobe.
Jobe.'s Avatar
70
Drives: BMW M3
It is unfortunate so see failures out of the S65.
I recently read your thread about your engine going boom. Sorry to hear about that.
      08-03-2018, 08:40 AM   #7
Mvy
Drives: 2008 E93 M3
I feel bad for you guys. Best of luck getting your cars back in action.
Harrop Supercharger, BPM Tune, aFe stage two airbox, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive...
      08-03-2018, 08:40 AM   #8
SYT_Shadow
SYT_Shadow's Avatar
It is sad. These are such wonderful engines, I hate to see them die.
      08-03-2018, 08:41 AM   #9
tdott
Drives: M3
Ouch
      08-03-2018, 09:25 AM   #10
dparm
dparm's Avatar
Drives: C7 Corvette Grand Sport
Would be curious to hear about the engine's history, e.g. maintenance, driving style, climate.
Now: 2017 Corvette Grand Sport
Past: 2011.5 M3 sedan ZCP
SFCM3708.00
      08-03-2018, 10:22 AM   #11
last1left
last1left's Avatar
175
Drives: e92 M3
Unbelievable just wow terrible this is
      08-03-2018, 11:23 AM   #12
Redd
More and more mains seem to be going. What's the recommended mileage to change the main bearings?
      08-03-2018, 12:33 PM   #13
TheRussski
TheRussski's Avatar
109
Drives: Slow
To service them you have to pull out the engine and itís just not worth it because in labor alone itís around $4k plus you will be putting in stock mains in there and the same problem will come up
      08-03-2018, 03:07 PM   #14
Honda
Honda's Avatar
207
Drives: BMW
what is the root cause for main bearings failure?
      08-03-2018, 03:12 PM   #15
SFCM3
Drives: 2011.75 E90 M3 ZCP
as would I.
oil service intervals is what im interested in, also was it tracked?
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      08-03-2018, 03:51 PM   #16
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
17410
Drives: ///M3-DCT- E92 Silverstone II
*BMW*
BPM DEV-Tune & DCT software update & Servotronic & coding///Alpine HID Angeleyes///Oem.exhaust mod.
admranger1085.00
      08-03-2018, 03:57 PM   #17
Mvy
Drives: 2008 E93 M3
Theory is same as rod bearings. Clearance and tolerance stack. They are in fact made of the same material as the rod bearings.
I always wonder if there is any correlation between the condition of the rbs and the mains. What scares me about your photos is how good the rod bearings look considering the condition of the mains. The rod bearings are worn but not terrible. That one main is so shot. By chance was that #1?
It shows you really cant make much of a judgement call on the condition of the mains based on the condition of the rod bearings.
I changed my rbs. Heres to letting it ride on the mains......
      08-03-2018, 07:34 PM   #18
Redd
But the alternative can't be to wait for failure right? Cos when it goes, it does so without warning and takes the entire engine with it. In other cars, main bearing failure is usually preempted by low oil pressure warning. In the S65 it appears not to be the case.
      08-03-2018, 08:30 PM   #19
TheRussski
TheRussski's Avatar
109
Drives: Slow
Failure rate for main bearings are very rare on non supercharged cars. I donít think as of yet we should all start to worry about it.
SYT_Shadow2705.00
      08-04-2018, 11:38 AM   #20
bigjae1976
bigjae1976's Avatar
613
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.00]
2013 BMW 328i  [5.00]
This is a tough one. I would not wait until the motor goes kaboom but its not cheap to address preventively. Can we monitor main bearing wear via oil analysis?
For track people who plan to keep an E46 M3 on track for awhile, it makes sense to keep a fresh spare motor on hand. I plan on annual motor swaps. Its not too bad as far as cost if you keep the internals stock. I plan on doing a basic check - leak down, rod bearing inspection, and look at the combustion chamber/bores with a boroscope.
Kind of harder to justify for an S65 since used motors are still $8kish and I'd be checking the mains too...which means total teardown.
2015 F34 328iX GT Glacier Silver
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
      08-04-2018, 12:59 PM   #21
sirploppy
5 Star General
44
Drives: 11 E90 M3
Now THIS is the stuff that keeps me up at night. Like many have done, planning on doing rod bearing replacement soon - BE bearings, ARP bolts. Then to see this, knowing that in spite of my due diligence and preventative maintenance, I might still be kicked in the balls at any moment. I know, there have been very few mains I've seen on here go so far, and you can't live your life in fear. It's just that I want to keep this car till the end of time and I just hate having the main/rod bearings of Damocles swinging above me.
      08-04-2018, 08:07 PM   #22
Redd
I think this is the opportunity for a stroker kit to go in. #MightAsWellBro 😂
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
