      02-05-2014, 04:29 PM   #1
Corpus
Drives: E90
I Help With A No Start Issue
I did a m3 motor swap in my e90 can't seem to firgure out why I'm unable to start her up here are the list of codes pulled. I'm also not able to see ekp in the list of modules in inpa.
[IMG]http://i809.photobucket.com/albums/zz17/***********/9069bca752155727e61cec6543bf3806.jpg[/IMG]
[IMG]http://i809.photobucket.com/albums/zz17/***********/0fa4cee3ecc7a989336ef226b81caff4.jpg[/IMG]
[IMG]http://i809.photobucket.com/albums/zz17/***********/75fb3650bdac11dc43fca9fe3d809dd9.jpg[/IMG]
      02-05-2014, 06:22 PM   #2
BPMSport
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [3.75]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Send a message via Skype™ to BPMSport
Look @ the module listing with AIF or Ident and see what's responding there.
Clear all of those faults, turn the ignition off, and then back on again.
You should see EKP for sure. The EKP module is located behind the rear seat corner on the passenger side.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      02-05-2014, 06:34 PM   #3
Corpus
Drives: E90
Thank you for responding mike
The ekp is not responding I tried in both inpa and ista
I had a few MRS safety codes which I resolved
I also haD a terminal 13 CAS code, associated to can pin #7 and #8 that I wasn't able to resolve. I removed pin 7 which cleared the code.
      02-05-2014, 06:38 PM   #4
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
2008 BMW M3  [3.75]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
It looks like you have can bus communication. I would check can power and ground at the EKP module.
Is the CAS, DME and key from the same car?
Make sure that you're seeing the ignition pin energize with KL15 on.
      02-06-2014, 07:33 AM   #5
Corpus
Drives: E90
I'll double check the wire at the ekp
do you know what desire voltage should be at the CAN wires?
Yes I was told that the motor cas and key are from the same vehicle
I'm not getting any errors in ista relating to that.
The cas and dme vin#'s are the same the key I'm assuming is correct.
KL15 I'm assume is terminal 15 correct?
Is it F38 at the junction box pin 19 at cas
Or pin 2 at relief relay ?
      05-26-2014, 06:26 PM   #6
Corpus
Drives: E90
Some help please I'm not sure why ekp is not showing up in inpa AIF list
Or in istaD list
Just about ready to give up
[IMG]http://i809.photobucket.com/albums/zz17/***********/Mobile%20Uploads/A08A23D1-3A40-4AF9-A449-52B8F31DD384.jpg[/IMG]
[IMG]http://i809.photobucket.com/albums/zz17/***********/77A86160-8B21-4A50-9DE3-4F469D3DF306.jpg[/IMG]
[IMG]http://i809.photobucket.com/albums/zz17/***********/C060C95A-6C53-44FF-95DD-C4D034980FBC.jpg[/IMG]
[IMG]http://i809.photobucket.com/albums/zz17/***********/Mobile%20Uploads/56C1237F-18BD-463B-BC64-9DA2ECAE3627.jpg[/IMG]
      05-26-2014, 08:45 PM   #7
Ging
Drives: m3
check the power wire and the ground wire by the positive boost post on the left side of engine bay. had many of the same codes as well as no start and was cause by the ground cable in the wrong spot. never forget to recheck the simple things to like power grounds and fuses. good luck
      05-27-2014, 05:49 AM   #8
Corpus
Drives: E90
Thanks I'll recheck those wires once again
      07-14-2018, 11:59 AM   #9
xarlock667
Drives: 2006 bmw e90
This sounds like a lot of not fun. I am trying to find out why my e90's ekp keeps dying. They are expencive to replace.
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
